Amp Help
Username: Tsrider
Tracee
Im waiting on a Alpine Dual 4 ohms Type-R 12 subwoofer does anyone have any suggestions on an amp that will push this sub good?
Username: Logan__tille
AudioqueUSA
Post Number: 1905
budget?
Username: Tsrider
Tracee
around $250
Username: Tjmutlow
Post Number: 3060
you can run a monoblock or a 2 channel at 4 ohms bridged. Maybe a memphis 100d or a kicker kx 1200.1, but prob need a few more dollars, or the hifonics 16069would like the others though first.)
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3037
alpine MRD 605 if youre only getting one dual 4 ohm sub.
If you're getting 2 then get hifonics1206d
AudioqueUSA
Post Number: 1906
i think he only has one.....so i would look at this http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3963
