Help me out with a quick question here
Username: Ndjumpman23mj
Post Number: 11
im trying to hook up my amps to my subs and my friends telling me to get an amp kit or some wiring, but he confuses the #$%^ outta me so can someone please tell me what i need to hook up my subs to my amps
amps- 2 audiobhan 8000v(800 rms each)
subs- POWER HANDLING 3200 WATTS TOTAL (2 X 1600 WATTS), IMPEDANCE: 2 OHMS/CHANNEL, SPL: 89 db,1 WATT, 1 METER, MAX SPL: 115 db, FREQUENCY RANGE: 20-250 HZ, 2" DUAL 4 -LAYER VOICE COIL
ya im jus putting most of the info that i know of my subs just to help you all out
any help appreciated thanks
Username: Freezeman_7
Lindsay, Oklahoma
Post Number: 433
you can order a two amp kit from www.woofersetc.com or jus buy two 4gauge kits from best buy wit a distro block.
Username: Disturbedpriest
Post Number: 196
okay so are they dvc 2 ohm subwoofers? or are they dvc 4ohm? for your amps all you gotta do is get a amp kit (or in your case) go by a local audio shop and buy a kit and have them install it or get your friend to help you out before you hurt yourself :-)
Post Number: 12
how much do you guys think im gonna be looking to spend around, i dont want to get ripped off
Username: Adddisorder
West palm, Florida
Post Number: 1332
get something off of knukonceptz.com or ebay
Username: James1115
Ct
Post Number: 7017
if you can wait order it online, if you need it soon and you go to worstbuy or circuitshitty you will get ripped off. Unless your friend really knows what he is doing I would have a local audioshop do the install. You will prob pay about $45 for a headunit, $50-$60 for a amp+ cost of amp kit and what not.
Post Number: 13
thanks, anyone else?
