Hearing loss....
Username: Thumping_corsica
Saginaw, miUnitd states
Post Number: 99
doesnt it suck that if u have music too loud, gradually you can lose hearing ;;wahhh
Post Number: 100
ive been doing some reading on this subject
Username: Logan__tille
AudioqueUSA
Post Number: 1925
haha yea, wear ear plugs.
Post Number: 101
u wear ear plugs?? i think ill try that..
Username: Extrmndor3
Chicago, Ill Us
Post Number: 2270
0 (N) BEGINNING OF HEARING, A MOSQUITO 10 FEET AWAY, THE EAR DRUM MOVES LESS -REF.1.1990
THAN 1 / 100 THE LENGTH OF AN AIR MOLECULE (N)
3.5 (P) 1E-10 METERS OF MERCURY = 0.0000000001 METERS OF MERCURY
10 (P) ABSOLUTE SILENCE, ATT-BELL LABORATORY " QUIET ROOM "
13 (P) ORDINARY LIGHT BULB HUM
15 (N) A PIN DROP FROM A HIEGHT OF 1 CENTIMETER AT A DISTANCE OF 1 METER -REF.1.2003
30 (P) TOTALLY QUIET NIGHTIME IN DESERT-IMPOSSIBLE ANYWHERE NEAR CITY
35 (P) ANECHOIC HEARING TEST ROOM -REF.1. 1998
40 A WHISPER, A NORMAL CONVERSATION IS 60 DB, NORMAL SOUND 70 DB -REF.1.1983
73.98(P) = 1 uBAR = 1 microbar pressure
85 BEGINNING OF HEARING DAMAGE, EARPLUGS SHOULD BE WORN
93.98(P) = 1 PASCAL PRESSURE
100 NORMAL AVERAGE CAR OR HOUSE STEREO AT MAXIMUM VOLUME -REF.1.1982
107-104 (P) THE BEGINNING OF PAIN AT THE MOST SENSITIVE FREQUENCY OF 2750 HERTZ -REF.1.1982
109 ONE SOUND WATT RADIATING AS A PERFECT SPHERE, 4 PI SQUARE METERS -REF.1. 1986
110 A CAR STEREO WITH TWO 6 X 9" SPEAKERS AND 100 WATTS -REF.1.1982
113.81(P) = 1 MILLIMETER WATER
114-107 A VERY LARGE, POWERFUL PORTABLE RADIO REF.1.1982
116 HUMAN BODY BEGINS TO PERCIEVE VIBRATION IN THE LOW FREQUENCIES -REF.1.1986
117-123 HOME STEREO SYSTEM, A VERY LOUD AND POWERFUL 200-2000 WATTS -REF.1.1983
120.24(P) ONE PURE SOUND WATT FLOWING THROUGH 1 SQUARE METER, YOUR ELECTRIC AMPLIFIER MAY BE 3000 WATTS.ALSO A TESTIMONY TO HEARING SENSITIVITY -REF.1.1986
120-130 FRONT ROW AT A ROCK CONCERT- UP TO 200 REFRIGERATOR SIZE SPEAKERS
AND 50000-300000 WATTS OF CLEAN, FULL FREQUENCY SOUND -REF.1.1981
125 DRUM SET-ONLY AT THE MOMENT OF STRIKING, CONTINOUS LEVEL 115
126-130 TYPICAL PROFESSIONAL D.J. SYSTEM -REF.1.1984
127 HUMAN TINNITUS (RINGING IN THE EARS) BEGINS -REF.1.1984
127.48 = 1 pound per square foot
128 (P)HUMAN, LOUDEST SCREAM MEASURED AT A DISTANCE OF 8 FEET 2 INCHES
128 HUMAN HEAD HAIR BEGINS TO DETECT VIBRATION -REF.1.1983
128 HUMAN CAN BEGIN TO DETECT VERY SLOW "BLAST WIND" OF 0.124 METERS/SECOND -REF.1.1983
130 (N)MARCHING BAND-OVERALL LEVEL AT A DISTANCE, 100-200 MEMBERS -REF.1.1996
132 EARDRUM "FLEX" TOTALLY NOTICEABLE -REF.1.1982
132.4(P) = 1 SOUND WATT MAXIMUM IN A SMALL SEALED BOX BELOW HYDRODYNAMIC CRITICAL LOW FREQUENCY
133 (N)GUNSHOT- EAR LEVEL, MAY VARY GREATLY TO SIZE AND TYPE OF GUN,
DURATION CONVERTED TO ONE SECOND, PEAK LEVEL MAY REACH 140-160 (P)
133.98 (P) = 1 MILLIBAR PRESSURE
135-122 (P) "VERY LOUD" CAR STEREO, ONLY BASS LEVEL, HIGHS RARELY ABOVE 115(P) -REF.1.1983
135-130(N) LARGE TRAIN HORN -REF.1.1985
135 HUMAN, A SLIGHT COOLING EFFECT BEGINS TO BE NOTICED, FROM AIR EXPANSION -REF.1.1983
136.498(P) = 1 TORR PRESSURE = 1 MILLIMETER MERCURY
137 HUMAN BODY VIBRATION IS STRONG -REF.1.1983
137-140 HUMAN EAR ALL FREQUENCIES ARE PAINFUL -REF.1.1983
140 EXTREMELY DAMAGING TO HEARING NO MATTER HOW SHORT THE TIME EXPOSURE
140 BLAST WIND = U = (PARTICLE VELOCITY) IS 0.49 METERS PER SECOND OR ABOUT 1 MPH
140 HUMAN THROAT AND VOCAL CORD VIBRATION BEGINS -REF.1.1983
141 HUMAN BODY BEGINS TO FEEL NASUEA AFTER A FEW MINUTES -REF.1.1983
141.918(P) = 1 INCH OF WATER PRESSURE
142 HUMAN BODY CHESTPOUNDING IS INTENCE -REF.1.1983
142 (P) INSIDE A CAR WITH TWO PRO 18 INCH WOOFERS AND 300 WATTS EACH -REF.1.1983
143 HUMAN BODY FEELS AS IF SOMEONE JUST FOOTBALL TACKLED YOUR CHEST -REF.1.1983
144 HUMAN NOSE ITCHES -REF.1.1983
145 HUMAN VISION BEGINS TO VIBRATE MAKING IT SLIGHTLY BLURRY, 1-3 DEGREES -REF.1.1983
145-136 (P)"COMPETITION" CAR STEREO, SIXTEEN 12 OR EIGHT 15, OR FOUR 18 SPEAKERS -REF.1.1983
146.1(P) AIR PARTICLE VELOCITY(WIND) IS 1 METER PER SECOND OR ABOUT 2 MILES PER HOUR
147 (N)FORMULA 1 RACE CAR, 700 HORSEPOWER, CHESTPOUNDING AND SUCTION FORCE ON CALM QUIET
MORNINGS CAN CLEARLY BE HEARD 6 MILES AWAY.-REF.1.1991
148 HUMAN VIBRATION VERY UNCOMFORTABLE AND SLIGHTLY PAINFUL -REF.1.1986
149 HUMAN LUNGS AND BREATHING BEGINS VIBRATING TO THE SOUND -REF.1.1986
150 (N)ROCK CONCERT "THE WHO" TWO 10 STORY STACKS = 144 DOUBLE REFRIDGERATOR SIZED SPEAKERS, ACTUAL LEVEL REACHED 120 DB AT A DISTANCE OF 32 METERS FOR THIS NORMALIZED READING OF 150 DB.CONTINOUS LEVEL 114-118db (P) AT 32 METERS -REF.1.1982
150 ROCK CONCERT SPEAKER AT 1600 WATTS ON THE ACTUAL VIBRATING SURFACE -REF.1.1991
150 HUMAN SENSATION OF BEING COMPRESSED AS IF UNDERWATER IS OVERWHELMING -REF.1.1983
150 HUMAN SOUND EXPERIMENTS DOWN TO 1 TO 2 HERTZ - REF.13.
152 HUMAN VIBRATION IS PAINUL AND ALSO FELT IN ALL JOINTS -REF.1.1983
153 HUMAN THROAT IS VIBRATING SO HARD IT IS ALMOST IMPOSSIBLE TO SWALLOW -REF.1.1983
154 TOY BALLOON POPPING, DEPENDS ON TYPE AND HOW LARGE AND HARD TO INFLATE -REF.1.1986
155 HUMAN BODY COMPRESSION AND EXPANSION TO VIBRATION IS TO THE "CORE" -REF.1.1983
155 HUMAN COOLING EFFECT IS HIGH, AS A GUESS 10 TO 25 DEGREES FARENHEIT? -REF.1.1983
156 (P)IN A MINI-VAN WITH TWENTY 12" WOOFERS AND 19,000 WATTS OF AMPLIFIER POWER.
EACH SPEAKERS IS DISPLACING (PUMPING BACK AND FORTH ) 0.75 INCHES
IF LONG HAIR WOMEN SIT IN IT, HER HAIR WILL FLY OUT OF WINDOW WITH BASS
WINDSHIELD WIPERS FLY OFF VEHICLE 1/2 TO 2 INCHES, DOOR AND FRONT
WINDSHIELD FLEXION MAY BE UP TO +-2 INCHES OR 4 INCHES PEAK TO PEAK
EVEN WITH EARPLUGS (-30 DB) AND HEADMUFFS (-24 DB) = -54 DB IT'S STILL LOUD -REF.1.1997
156.498(P) = 1 CENTIMETER MERCURY = 0.01 METERS MERCURY
158 HUMAN BODY VIBRATION IS VIOLENT, NAUSEA BECOMES MORE INTENCE -REF.1.1983
158 (P)INSIDE A ROCK CONCERT SPEAKER BOX REFRIDGERATOR SIZE AT MAX. 5000 WATTS -REF.1.1983
160 (P)FLASHLIGHTS EXHIBIT ELECTROMAGNETIC PULSING-EMP (DIMMING DURING SOUND) -REF.1.1983
162 U.S. FESTIVAL ROCK CONCERT 1983. 10 SEPARATE STACKS, AMPS = 400,000 WATTS (N) -REF.1.1983,-REF.3.
163-153 (N) N.H.R.A. DRAGSTERS- 5000 TO 7000 HORSEPOWER, LIQUID NITROGLYCERIN FUEL,
EARTHSHAKING AT 50 FEET, HUMANS FIND IT HARD TO SEE, AND BREATHE 140db(P) -REF.1.1987
163 (P)GLASSBREAKING LEVEL, MINIMUM, IT IS VERY HARD TO BREAK GLASS WINDOWS.
MANY STORIES COME FROM BREAKING GLASS BUT IT IS HIGHLY VARIABLE: IT IS
EASIER TO BREAK IF THE WINDOW ALREADY HAS A CRACK, IS VERY LARGE OR
OLD AND BRITTLE AND NOT CAR SAFETY GLASS WHICH CAN FLEX MASSIVELY
BEFORE BREAKING. AN OPERA SINGER AT 110 DB MAY BREAK A WINEGLASS BUT IT IS AN
EXAMPLE OF FREQUENCY RESONANCE, AND NOT HIGH SOUND DB LEVEL -REF.1.1987
163 (N)OCEAN WHALE REFERENCE 2 EXP-5 NEWTONS PER SQUARE METER
164 (P)INTERNAL SOUND PRESSURE OF A LARGE JET AIRPLANE TURBINE MOTOR -REF.1.1993
164.568(P) = 1 INCH MERCURY PRESSURE
165-145 (NP) THE COMMON TYPE OF FIREWORKS AT PROFESSIONAL PYROTECHNIC SHOWS -REF.1.1988
165 (N)JET AIRPLANE, BOEING 727-15,000 LBS OF THRUST, DEPENDS ON THE TAKEOFF -REF.1.1982
165(P) MOTOR DRIVEN PISTON HEADPHONES -REF.16.
166 AIR PARTICLE VELOCITY IS 10 METERS PER SECOND OR ABOUT 20 MILES PER HOUR
170.75 PRESSURE (P) = 1 P.S.I. = 1 POUND PER SQUARE INCH MOST SOUND READINGS
HIGHER THAN THIS REFER TO P.S.I. INSTEAD OF DB. BUILDINGS AND HOUSES
HAVE APPROXIMATELY A 50 % CHANCE OF SURVIVAL REF.2.
171-150 (P)WORLDS LOUDEST CAR STEREOS, UP TO 80 SPEAKERS,32 CAR BATTERYS,
100,000 WATTS, 125-138 (N)
171(P) acoustic air pressure generator -ref.12
172 (N) 727, 737, 747, 757, 767 CRUSING AT 6 MILES HIGH MACH 0.84, AT THE GROUND (SEA LEVEL) LOSES AN ADDITIONAL 6 DB BECAUSE AIR DENCITY IS ONLY HALF SEA LEVEL AT A HIEGHT OF 6 MILES
172 FOG IS CREATED, DEPENDING ON THE TEMPERATURE, DEW POINT AND HUMIDITY
173-164 (P)BASS INJECTION TESTS, EXPIERIMENTAL ELECTROMAGNETIC TYPE SPEAKERS -REF.1.1987
173(P) = hydraulic, whole body dynamic pressure chamber, at 8 hertz -ref.11.
174 AIR BEGINS TO HEAT UP DUE TO COMPRESSION, MOST SHOCK WAVES ARE VERY HOT
174(P) LOUDSPEAKER COUPLED MANOMETER HEADPHONES DOWN TO 1 HERTZ -REF.15.
175 (N) QUARTER DYNAMITE STICK, VERY CLOSE PRESSURE MAY EXCEED 210 db (P)
175.8(P) 1 TON T.N.T. AT 250 FEET
177 (P) = 2 P.S.I., DAMAGE TO STRUCTURES ARE SIGNIFICANT, 30% SURVIVAL -REF.2.
180 (P) 1 POUND T.N.T. AT 15 FEET -REF.4.
180 (P) = 3 P.S.I., DAMAGE TO STRUCTURES IS CATASTROPHIC, WHEN A SHOCK -REF.2.
WAVE HITS A STRUCTURE ITS MOMENTUM AND PRESSURE MORE THAN DOUBLES, ESPECIALLY AT HIGHER DB LEVELS, DYNAMIC WIND IS ABOUT 103 MILE / HOUR
AND CAUSES A LARGE PORTION OF DAMAGE, 15 % OBJECT SURVIVAL -REF.2.
180 (P) = MOTOR DRIVE COUPLED MANOMETER STATIC PRESSURE, 165 DB(P) UP TO 50 HERTZ, -REF.14.
182 (P) 1 TON T.N.T AT 150 FEET, EXACTLY 182.2 DB -REF.4.
183 (P) = 6 P.S.I. TOTAL DESTRUCTION OF ALL STRUCTURES, PARTICLE VELOCITY
(BLAST WIND) IS 180 MILES PER HOUR. 0.9 MILES FROM HIROSHIMA ATOMIC BOMB
AND 3.3 MILES FROM 1MEGATON NUCLEAR BOMB, LESS 0.1 % OBJECT SURVIVAL -REF.2.
185.75 (NP) 0.375 POUNDS OF T.N.T. RIECHTER -1.5
186.1(P) 1 POUND T.N.T AT DISTANCE OF 10 FEET -REF.4.
187 (P) 1 TON T.N.T. AT 100 FEET, EXACTLY 186.8 DB -REF.4.
190.60 (NP) RIECHTER SCALE 0 (ZERO) EARTHQUAKE
190.60 (NP) 2.0000 POUNDS T.N.T.
191 (N)BOMB-VERY SMALL 1 LB. OR GRENADE, VERY CLOSE PRESSURE MAY EXCEED 210 db (P)
193.806(P) = 1 KILOGRAM PER SQUARE CENTIMETER
193.979(P) = 1 BAR PRESSURE = 14.504 POUNDS PER SQUARE INCH = 14.504 P.S.I.
194.09(P) = 1 (ONE) AIR ATMOSPHERE = 14.6962 POUNDS PER SQUARE INCH = 14.6962 P.S.I.= 1 ATM
SOUND WAVES DISTORT AND ARE NOW DEFINED AS SHOCK WAVES AND THEY BEGIN TO FOLLOW SHOCK WAVE BEHAVIOR. PARTICLE VELOCITY (BLAST WIND) = 590 FEET / SECOND = 180 METERS PER SECOND = 402 MILES PER HOUR. -REF.2.
194.1(P)EXACTLY, 1 POUND T.N.T. AT 6 FEET -REF.4.
195-190 (P) HUMAN EARDRUMS RUPTURE 50 % OF TIME -REF.2.
195.2(P) 1 TON T.N.T. AT 60 FEET -REF.4.
200.59 (NP) 63.24 POUNDS OF T.N.T., RIECHTER SCALE 1
Chicago, Ill Us
Post Number: 2275
When your ears are mad at you, they will "ring" (doctors call it tinnitis). Sometimes they will "ring" instantly, from gunfire or sometimes you will hear ringing the same night when your trying to go to sleep or even sometimes the next day. If your ears ring "you had it to loud", turn it down next time until you dont get the ringing anymore. If you keep abusing your ears the "ringing" won't kill you, but it can, and will get LOUDER until it will keep you awake at night(no way that is cool). Furthermore, if the ear abuse continues your ears will NEVER stop ringing and that fun part is you get to live your life with poor quality sleep FOREVER...
We recommend that you limit the amount of time you spend listening to loud music to 1 or 2 songs per day(usually no ringing if not to loud 100 to 120 db bass only), or just wear earplugs and turn it up to feel the vibrations beat you up. The level of damage is also changes with frequency. From hundreds of people it has also been determined that frequencies below 40 hertz can be about 10db louder than bass above 40 hertz. This is very important because most of the top of the line woofers can play significantly large amounts of power below 40 hertz. So if your system has an equalizer booster or bass frequency controller, you can shift the bass frequency lower(below 40 hertz) you can get more vibration AND at the same time be safer for your ears. We also agree with everybody else that an electric guitar solo frequencies( 1 to 4 kilo hertz) are really bad for your hearing, but equally there is no way that over +120 db bass can be good for you. Ipods can also be bad for your hearing, if there to loud. Remember, you can always buy new amps and speakers but you cant buy new ears.
Username: Mygame5982
H-TOWN, TEXAS US
Post Number: 631
i wanna hit 186.1(P) 1 POUND T.N.T AT DISTANCE OF 10 FEET
Chicago, Ill Us
Post Number: 2278
yeah u do that
Chicago, Ill Us
Post Number: 2279
i wanna hit 320 db's
320 (N)VOLCANO ERUPTION, TAMBORA INDONESIA,1815, EJECTED 36 CUBIC MILES.APPROXIMATELY EQUAL TO
14,000 MEGATON NUCLEAR BOMBS OR A 14 GIGATON BOMB BASED ON EJECTED VOLUME,CHANGE IN MEGATONS TIMES 1.345 EQUALS VOLUME EJECTED CHANGE.IF WAS A NUCLEAR BOMB IT WOULD CREATE A CRATER ABOUT 12.4 MILES WIDE AND 1.33 MILES DEEP.INTERNAL PRESSURE IS BELIEVED TO BE ABOUT 47 MILLION P.S.I. = 347 DB (P) -REF.1.3.
H-TOWN, TEXAS US
Post Number: 633
i wish fool
Username: Renegadesrun
Lafayette, IN US
Post Number: 441
"145-136 (P)"COMPETITION" CAR STEREO, SIXTEEN 12 OR EIGHT 15, OR FOUR 18 SPEAKERS -REF.1.1983"
LOL....or 1 8? We must have gotten better since this was made.
Post Number: 102
yes i dont get that one...
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1339
ditto .. my ears constantly ring slighty but i think that was from gunfire.. the car audio only helped it a little lol. when i got a hearing test a few months ago i had perfect hearing... kinda shocked me but the ringing is annoying
Username: Splmonster
Nowhere, OH USA
Post Number: 519
i was reading...... i think it was sport compact car, and they had a pioneer ad for the 180 vehicle or w/e and i coulda swore in there they said 180 was like hearing a ton of dynamit 15 feet away, but on here it says a pound of dynamit, hmmmmmmmmmmmm
Username: Insearchofbass
Post Number: 4877
Ive said this before but Ill say it again ....from my experience the reason I used to turn my volume up so high when i really examined it was because I wanted to hear all the detail of the music clearly if you dont hear the detail you want at a low volume then you either need to add other speakers to fill the gap or your system is not adjusted properly
