Bronze Member Username: Sk8erjimScottsmoor, Florida U.S. Post Number: 39 Registered: Jun-06 | could u guys suggest a cheap but good mono amp that puts out 1000 watts rms at 1 ohm? |
Silver Member Username: Audioguy22S.F., Cal. Post Number: 279 Registered: Jul-05 | Used Crossfire BMF1000D or CFA1000D can be had for under $200. and will do a little better than 1000w into 1 ohm. |
Gold Member Username: Logan__tilleAudioqueUSA Post Number: 1936 Registered: Feb-06 | do you have a budget? |
Bronze Member Username: Sk8erjimScottsmoor, Florida U.S. Post Number: 41 Registered: Jun-06 | what site could i get a crossfire off of? |
Silver Member Username: Audioguy22S.F., Cal. Post Number: 280 Registered: Jul-05 | ebay, they come up every 3 weeks or so. |
Bronze Member Username: Sk8erjimScottsmoor, Florida U.S. Post Number: 42 Registered: Jun-06 | ok, thanks! |
Silver Member Username: JohammbassCork, Co.Cork Ireland Post Number: 350 Registered: May-06 | cheap but good |
Gold Member Username: Matt12490The biggity biggity BAY, California USA Post Number: 1405 Registered: May-05 | ahh contradictions... |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3059 Registered: Dec-05 | Damn Good, if you can't find one then tell us a budget and we might tell you a good/cheap amp |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 9641 Registered: Jul-05 | http://www.tc.umn.edu/~erik0023/AudioEquipment/Crossfire/CFA-1000D.htm |
