New Box Sketch Up
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1286
17 x 39 x 16.5
5.046cu.ft (before displacement)
3 ports:
28hz - 10 x 3.5 x 25
35hz - 10 x 4 x 16.5
40hz - 10 x 6 x 20.5
The front of the box that is grey will be carpeted and mounted behind the rear seats directly to the trunk. The purpose of it is to seal off the trunk from the cabin. Not only that but it will make for a lot cleaner looking install :-). Of course that part will be assembled in the trunk first then the box will slide to it where it will then be mounted. This is a rough sketch but you get the idea..
Username: Adddisorder
West palm, Florida
Post Number: 1305
looks cool, so i take it your looseing the back seat?
one thing to consider is after you put screws in and out of the same hole in mdf it doesnt really stay in there becasue it doesnt grip anything. so if your changing ports a lot the screws might not hold after a while so maybe think of a better way to keep it attached
Username: Frkkevin
Post Number: 1287
t-nuts and bolts for the ports :-) .. back seat is staying. this just mounts directly behind the back seat in the trunk.
Username: Redliner
Wilmington, Ma
Post Number: 2713
ya thats what t nuts and bolts are the best for
Username: Safe_cracker
Chicago, IL US
Post Number: 1680
Very nice! :-)
Username: Frkkevin
Post Number: 1289
Hopefully it gives the same performance if not better than my current box
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 3527
looks great kevin!
Pine hill, Nj US
Post Number: 575
That box design looks....Upload
Username: Matt12490
The biggity biggity BAY, California USA
Post Number: 1382
G@Y?
Username: Extrmndor3
Chicago, Ill Us
Post Number: 2161
hey kevin wat do you use to make those designs???
Username: Frkkevin
Post Number: 1290
google sketchup
Chicago, Ill Us
Post Number: 2165
thanks man
Username: Frkkevin
Post Number: 1291
i use bass box pro 6 for the actual box and then transfer my plan to sketchup
Username: Kai2780
Post Number: 14
so, you insert the t-nuts into the baffle and then attach using screws through pre-drilled holes in the box. is this coorect?
will you be rounding the edges of the baffle?
Username: James1115
Ct
Post Number: 6963
look's sweet, that's a really good idea:-)
Username: Frkkevin
Post Number: 1293
yes .. and no .. the only edges that will be rounded is the port edges
Username: James1115
Ct
Post Number: 6965
smart! best way to avoid port noise.
WASSUPUSA
Post Number: 6312
take some sponge out of your backseat so the bass will enter the cabin better with the seat up.
nice design btw. looks like its going to take some time to build. have fun. too much work for a lazy azz like me though. lol.
Chicago, IL US
Post Number: 1683
Hey how about "donating" me a copy of Bass Box Pro 6 ? Let me know, I can PP some "Donation Funds" to ya, lol. Polo.. :-O
