Just figured I'd give you guys a small update... I've been slacking but I finally got around to working on my amp rack and such today. I ran into a problem as far as the wiring will go for the power and ground but I think I have a solution.. The battery posts you can buy and use for side mount.. well I need to use to of those and connect them to the input side of my amp and then I'll be able to use lug connectors to connect the power and groun to my amp.
Not enough room to have a reducer for 1/0 - 4 and still fit into the input side... not even enough to cut the wire down to fit cuz 1/0 won't bend enough to fit in the gap but I'll make it work
sorry for the crappy pics again.. i do have a digi cam i borrowed and well idk what happened
i took pictures and i went to upload them.. the program closed when it was done and i could not find them.. so i started to upload it again then i realized my prefs were wrong and i had to set a folder. i uploaded pics once before and it worked fine but i had to save them a different way.
i changed the prefs and then clicked cancle on the upload and it just sat there.. so well it annoyed me so i disonnected the cable and then exited the program
ever since then when i try to open the program it opens on the toolbar but shows nothing on the desktop. the little icon that says photoloader on the bottom right is up and it says automatically uploading.. but what?! there is nothing connected lol.
I've tried un-installing and re-installing and it does the same thing.. i guess im screwed. Bah!
btw.. I'm going to run 8awg through those I-hooks on the side of the amp.. I'm sure you guys were wondering why the héll I had those on there.. the 8awg will be the wiring for the sub.. should look cool
.. I've got plenty of room for the RCAs and speaker wire on the top.. and just enough room to ajust the amp... with my new plan I'll finally be able to run the power and ground
thanks.. still not mounted.. just set it in place to get an idea.. should be mounted this weekend and if i can find someone with a DMM i might just hook it up to that SX to bring it alive! but i was tempted to start a new box.. so well see
The amp mounted on the side is going to go... Need to sell it but I'm unsure for an asking price
Hopefully this weekend it will actually get install although if I have the spare cash I'm gonna go ahead and start the new box..
Might just install the new amp anyway and see what happens then install the new box and hope I don't see a dramatic drop in SPL. Hopefully I see a gain
