New member Username: Bek36Post Number: 1 Registered: Oct-06 | Been out of the loop so long.. not sure where to start now.. DTV or Dish? Have older equip for dtv, and about 1 yr old equip for dish. Do I need different dishes? any good resources for getting started? |
Silver Member Username: VinidominePost Number: 206 Registered: May-06 | God... hard to tell but I kinda like dish. As far as dishes, dish should install it free for you. |
Silver Member Username: JojogunFairfield, CA United States Post Number: 196 Registered: Apr-06 | Dish will install your dish free if you subscribe. But if you're talking about going FTA I don't think they'll install a dish for that. |
Gold Member Username: LklivesPost Number: 4722 Registered: Jan-06 | U cannot hack Directv...U can dishnet and Bev..I have posted a thread "REPUTABLE Dss sites"...use that list of sites and pick anyone based upon your receiver type...FTA (free to air) receivers are much easier and cheaper than hacking with plastic access smart cards and receivers.. I would highly suggest a Viewsat (any model) receiver and use |
Bronze Member Username: Vasia22Post Number: 44 Registered: Jun-06 | hi ppl! please help! i got koolsat 6000, uploaded the new 135 bin it worked perfectly but after, while i was watching, its just turned off, i tryed to reupload the bin,the only thing i didnt do is thoose 78 79 slots which had to be deleted. instead of chennel number on display it shows some lines flying around, and it actually uploads the bin and not the channels it gets stack on like 5 %. Anyone any advice or or the source of litrature to start debuging it |
Bronze Member Username: KllPost Number: 75 Registered: Jun-06 | Did you try to turn back power switch off and on |
Bronze Member Username: Vasia22Post Number: 51 Registered: Jun-06 | whats the factory bin for colsat 6000? 100? |
Gold Member Username: LklivesPost Number: 4735 Registered: Jan-06 | LMAO...I knew u were going to ask!...U really need to READ and LEARN...and become self sufficient!...FTA is NOT that hard, just READ! U should register FREE and join the DSS site below...they are the HOME DSS site for Coo*lsat!...that means they specialize in coo*lsats!..and thats where all the newest files are FIRST released...and all the manuals and guides and help forums..this site, Ecoustics" is NOT reallyt a "true" DSS satellite web site! COO*LSAT6000_100_20060308.zip ...Factory bin for cool*sat 6000 Register here: [link removed] File is located here.. [link removed] |
Bronze Member Username: KllPost Number: 79 Registered: Jun-06 | I don't have them handy you can get them at dss tester.com It is 120 |
Bronze Member Username: Vasia22Post Number: 53 Registered: Jun-06 | LK the problem is not where to download the COO*LSAT6000_100_20060308.zip, its just not working ... |
Bronze Member Username: Vasia22Post Number: 55 Registered: Jun-06 | LK the problem is not where to download the COO*LSAT6000_100_20060308.zip, its just not working ... but thankx for helping |
Gold Member Username: LklivesPost Number: 4738 Registered: Jan-06 | GO READ!...then maybe U will learn something...quit asking these same basic questions that are all answered after 1 hour of reading!...and the factory bin will clear your receiver for input of the nite rider lights...and U must shut off 78 and 79 keysets when using bin 135, which u already knew but ignored!..so go READ and POST at the COOLs*at HOME site I linked U to..U will get faster and more accurate info there.. |
New member Username: GonigunzStaten island, New york United states Post Number: 3 Registered: Oct-06 | hey i got pan 2700a and its not working with the new keys i have no clue wut 2 do can u plzz help me tell me wut 2 do plzzz email me plzzz xxgd2002xx@aol.com |
New member Username: Tomas_rocaWestchester, Il Usa Post Number: 1 Registered: Oct-06 | i need a lot of help. I have a cooltec model x-00cl and it dosent work, i have tryied a lot of keyes and dont see anyrthing. is there any body here who can help me? thank soo much in advance and im in zero................ |
Gold Member Username: LklivesPost Number: 4793 Registered: Jan-06 | I do NOT believe cooltec (a terrible- no software clone receiver) has a WORKING bin now, or for months.. Go to [link removed] ...register FREE there and then READ there...its best site for ALL clones like yours.. |
