hello.. i have a kenwood dvd/navigation and i jus got it all back together from someone trying to steal it.. i have never had navigation hooked up and working and was wonding what all i needed to do to get it to work.. thanks
if you know how to install a common head unit, then it should be no problem for you to hook up a navigation system. Most of the time the only problem lies with hiding all the wires and the hide-away unit.
