Bad or scrambled channels
Username: Rbhoop
Post Number: 10
Hi All.. iam getting alot of bad or scrambled channels now using the 279t bin .If i use the 281t should it recitfy this problem? Thanks all for any input.
Username: Piccalo
Post Number: 84
hey Ron.....trying switching the receiver off and turn the switch back on.....that should do the trick and try using the new keys
Username: Lroy
Post Number: 106
Ron all u have to do is to load the 281t bin, set TP autoupdae off and turn autoroll on then connect your box allow it to roll keys and you are done. Enyoy free TV....
Username: Machedonul
Post Number: 75
yeah ron, go to 281T
im using it and im happy with it
