Memphis vs JBL vs MB Quart vs Phoenix Gold
Username: 95caprice22
Richmond, VA
Looking to upgrade my system and I need an amp with about 1000 watts. I wanted to see some of your opinions about some amps. It will be pushing an ID MAX 12.
Memphis PRD1000.1 - 1000 watts @ 1 ohm
JBL GTO1201.1 - 1114 watts @ 2 ohms
MB Quart RAA1000 - 1000 @ 1 ohm
PG Xenon 1200.1 - 1200 watts @ 1,2,4 ohms
lookin for the best SQ and power to play for a long time cus i like to listen to my music. each are in the $350 - $400 range. any other suggestions in this price range would be helpful too.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2914
memphis is the best but i'd pick THE PG cuz it gives you more wiring options.
Username: Rovin
Trinidad & T...
Post Number: 9358
agreed ^^^^^^.........
Username: Rovin
Trinidad & T...
Post Number: 9359
aw shucks now noticed ur pushing a IDMAX
u dont need 2 buy a 1200+wrms amp 4 that sub since it only needs about 800wrms 2 work @ full output - i would play it safe & get that MB amp or memphis since those others put out over 1200wrms ......
Username: Juliob
Post Number: 2919
set the gain lower and you'll be fine
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1314
always better to have more than less.. its not like 1200 is to much for it either
Username: Tjmutlow
Post Number: 2983
good luck even on ebay to find the PG hard to find and it is a discontinued item.
