QUICK BOX QUESTION
Username: Nyyfan13
VA USA
Post Number: 329
alrite, making the box, got some of it cut and we went to make sure the screws we got would work. so we pre-drilled the holes and screwed the screw in. the wood cracked. tried it again, same result. tried a bigger pre-drilled hole, no luck.
please someone tell me how to do this without the wood cracking.
thanks
Username: Rovin
Trinidad & T...
Post Number: 9363
use thinner screws like gypsum/drywall screws which is what i use
also dont put screws too near the ends of the piece of mdf - put it about 2" away @ least
note if u use liquid nails it actually holds steonger than screws itself .....
Username: Nyyfan13
VA USA
Post Number: 330
alrite thanks rovin, but we figured it out and it works fine now.
Username: Tremor1127
Post Number: 293
yes, keep them from the ends, ends split easy... is there not a slightly larger bit you can use?
Username: Nyyfan13
VA USA
Post Number: 332
yea thats what we did and it works fine now
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1316
you dont have to use screws, u can clamp everything .. of course it takes a hell of alot longer to assemble it
