Help :-(
Username: Makmillion
MN United States
Post Number: 1185
I got my crimpable 1/0awg 0-rings today.. and I went to crimp one on and don't have a crimper strong enough to tighten it down to where it needs to be.. so I was thinking about soldering the tips onto the wire.. you guys think the metal tips will hold up? They're solid brass with gold plating..
Username: Tjmutlow
Post Number: 2979
use a table vice, or hammer it down and then solder it on.
MN United States
Post Number: 1187
Do you think the metal will fold? or will it hold up to the heat of the solder gun?
Username: Rovin
Trinidad & T...
Post Number: 9362
do waht Ty said - thats what i normally do ....
MN United States
Post Number: 1188
Okay, thanks guys :-)
