Sound deadner
Username: Adddisorder
West palm, Florida
Post Number: 1190
i know people on here have tryed using home insulation for sound deadning, whats the results? worth it?
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1190
I'd like to know this as well.. i heard a lot of people using peal-n-seal .. $1 a foot can't go wrong... if it works i'll give it a shot as well :-)
Username: Basshead86
Try Google
Post Number: 6987
it is asphalt-based correct?
that would be the only downside next to possibly the adhesive factor(stickyness) i would think of before buying it. give it a shot man:-)
Username: Frkkevin
Post Number: 1191
well if it doesn't work its not like it was that much money :-)
Try Google
Post Number: 6993
exactly!!^^^
West palm, Florida
Post Number: 1214
well the home insulation stuff is fiber glass or somehting like that. i remember doing construction one time and that stuff makes you ITCHY! ill probly add it to my list of stuff to get sometime to test out. or maybe ill just steal some from my attic
Username: Kickdoor
Post Number: 62
lol does that stuff really work it would look crapppy though pink stuuuff everywere im gonna try out peel n seal from lowes on my friends car see how it truns out.
Username: Frkkevin
Post Number: 1197
^^ Lol.. thats how you do it.. pawn it off on a friend and if it turns out good do it on your own car :-)
West palm, Florida
Post Number: 1233
well i wouldnt just stick it to my car id hide it under carpeting and stuff in the trunk.
whats peel and seel, not familure with it
Username: Mike_16
Reedsburg, Wisconsin Us
Post Number: 116
yea were can you get peel and seel
Username: Frkkevin
Post Number: 1231
home depot or lowes ..
http://www.paceproducts.com/peel-n-seal.htm
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1315
do it right..
wwww.secondskinaudio.com
best products.. good prices
peel and seal will peel off in hot weather.. fibreglass insulation is a bad choice seing as how its carcinogenic, im sure you dont want that stuff flyin around in your car all day
Username: Bernymac
Rialto, CA United States
Post Number: 486
Or you can go with raammat, second best, and better prices.
West palm, Florida
Post Number: 1240
another thing i just thought of would be like the foam stuff under carpet, its like 20 for an 8x4ish roll
Username: Frkkevin
Post Number: 1242
I've seen a few people use peal-n-seal.. it is rubberbased not fiberglass and it sticks fine as long as you clean the surface well.
first wash it with soap and water and then go over the surface with some rubbing alcohol
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 367
I have peel and seal in my Jeep and for the price it is worth it. Didnt stop all the rattle but I can definatly tell a big difference and it sticks fine and I cant smell it or anything... Definatly worth it to me
