Horse Racing channel Anybody help?
Username: Quicksilver_112
Post Number: 37
Hi i downloaded the newest viewsat bin on my new extreme for bev but i get no horse racing cahnnels they dont even appear on the guide so does this mean i gotta change the sat and do another blind scan?...
does anybody no what satlite the horse racing channels on so i can get everything with them as well thanks
Username: Header108
Post Number: 21
the horse raceing is on (Echo 8.1) Sat or on some older bins it is on Sat (Echo 8.6) same Sat just diff numbers
Post Number: 38
do ya still got all the channels tho even tho its that satilite...?
Username: Albino_midget
Post Number: 217
hrtv-echo8/10 tp-12428
tvgam-echo7 tp-12457
Post Number: 39
got 2 of the racing channels down the hpi- c and hpi-w ones it says searching satlite but nothing ever comes up..... should i do a blind scan or wat do i do toi fix it.....thanks
Username: Header108
Post Number: 22
What sat are you on, just scan that transponder on Echo/810 or Echo7 the transponders are above your post by Albino Midget
Username: Franktodd
Post Number: 18
hrtv110,tvg119,hpi91
Post Number: 40
so i should do a blind scan of my satlite im on and should come up or what?
Username: Franktodd
Post Number: 19
latest bin file and blind scan, than catch the 7th at oak tree.
Username: Ong_tu
Post Number: 196
19052 ITVGV (TVG) AND 404 Horseracing (HRTV)let me know if you still can not get them.
Post Number: 43
so do a blind scan then and they might pop up
the channels are 2475 and 2477 anybody ele out on there view sat extreme
