Bronze Member Username: SimikangPost Number: 86 Registered: Jul-06 | does anybody have the newest channel list fixed with the channels that went missing, i cant make one because i dont have a signal on that dish yet. if anyone does please msg me or email it to me at sim.kang@gmail.com |
Bronze Member Username: FidarahmanPost Number: 65 Registered: Nov-05 | Just blind scan and if the dish is pointing correct to 61.5, you should get all channels |
Bronze Member Username: Dave_singhPost Number: 46 Registered: Jun-06 | CAN SOME ONE TELL ME THE ANGLE , FOR 61.5 DISH |
Bronze Member Username: SimikangPost Number: 88 Registered: Jul-06 | for those that didnt get the indian channels working i have the channel list of echo 3 with the tp's for those channels updated. msg me if you need it |
Bronze Member Username: FidarahmanPost Number: 66 Registered: Nov-05 | The exact angle is 61.5 degrees West. Roughly when you face the sunrise direction, it is to your right arm stretched towards right. |
Silver Member Username: Bones714SO.California Post Number: 144 Registered: Mar-05 | Will i pck up any vietnamese channels on this setting(61.5)w? can i use any satellite dish for the 61.5w or will it have to be a 33"? |
New member Username: Adam_paulPost Number: 1 Registered: Oct-06 | Well, the way you should try out is that Go for echostar 8,10. Choose the TP settings and delete all the TP that are in there but one 12220/V/Auto. Come out of that screen and go to blind screen mode. Blind scan, it will pick up all the channels. |
Gold Member Username: LklivesPost Number: 4633 Registered: Jan-06 | Satellite Finders (Look Angle Calculators) ------------------------------------------------- [link removed] |
