Pansat 2700A
Username: Jack786
Hello folks,
I just bought a new Pansat 2700A (IR). Last night I loaded the bin which i got from pansat website. I assume it's the latest version. during the load it asked me if i wanted to load app file only, channel data only, transfer only. Which one do i select?
Also where do I get the latest code to get the south asian channel and Cricket. My dish is pointed at 61.5 I live in connecticut.
I'm new to this so any help will be greatly appriacated. Thanks.
Username: Jack786
Can some one please answere. Thanks.
Username: Alishahid24
choose app file only. leave others as it is.
all bins are good. 274,275,279. Make sure you get the latest keys. its in these forums somewhere. you have to look for it. turn the auto roll off and auto TP off as well. lemme know if that helps
Username: Jack786
Thankf or the reply. the file i had is pansat2700a_060526_115_api.bin. Is this one of 274,275,279?
Thanks again.
Username: Agalya
if u have pointed to 61.5 then choose echo star 3
and do blind scan first
check the signal
- for new bin - select app file only.
make sure com setting is correct
enjoy!!!!
Username: Jack786
thanks buddy. Do i need to replace the LNB? Currently it's the one supplied by Dishnetwork. And do you know the latest key, i get all confused by this. there's like 100 posts on it with everybody posting different key, which one will i need?
Thanks.
Username: Hawaiian_time
Hawaii
Post Number: 651
jack, the 060526 part of the bin you have is the date. It is an old bin. You should look for the X-87BL_061011_279 bin, which has a working auto roll.
Username: Jack786
where do i get this updated bin from?
Thanks.
Hawaii
Post Number: 652
Sorry jack, the bin you have is the factory bin. Load that first, then the 279 bin.
Hawaii
Post Number: 653
dsscommunity.c@m has it
Username: Jack786
Post Number: 8
I've already loaded the factory bin. dsscommunity is blocked site from my work, so i'll have to get it once i get home.
Hawaii
Post Number: 654
I prefer future-fta.inf@, need to register first though.
replace @ with o
Username: Jack786
Post Number: 9
lol, that's blocked too.
Hawaii
Post Number: 655
wow, at least your company lets you come here! lol
Username: Jack786
Post Number: 10
tell me about it, by the way, i really do appreciate you guys trying to help me out.
hopefully i'll be able to ge the latest bin at home. what do i need to do next?
Username: Osc
PUERTO RICO
Post Number: 112
THIS IS IT JACK
http://www.future-fta.info/Forums/showthread.php?t=35261
Username: Jack786
Post Number: 11
thanks Buddy, I'll check it out once i get home.
