Real quick question. I have a Dish 500 and two Pansat 3500SD's. Can I use a cheap disecq switch or do I need to get a multi-switch to be able to use both recievers at the same time and watch different channels. If I need a multi-switch which is the best kind to use?
i got pansat and cw600p and one dish on your lnbyou shoud be abble to go to your dish and run a cable next to the first cable on your dish and run it to the other box it works good for me two boxs watch two difrent channels at rhe same time
