Username: Tariqic Post Number: 81 Registered: May-06
Wednesday, October 18, 2006 - 01:45 GMT I have 2 receivers, a CK5000 and shorting receiving an Viewsat Xtreme. How can I hook up both receivers to watch BEV? Thanx
Username: Sakapfet Post Number: 157 Registered: May-06
Wednesday, October 18, 2006 - 02:13 GMT you need a switch or a splitter like the one you use to share rogers cable
Username: Nikk Post Number: 431 Registered: Sep-06
Wednesday, October 18, 2006 - 02:26 GMT T... Check your receivers, at the back they must have a "IF OUTPUT" conection, what you have to do is just connect one receiver to the dish and the other to the "IF OUTPUT" of the first one....
Username: Ke5aqn Shawnee,
OK
Post Number: 34 Registered: Sep-06
Wednesday, October 18, 2006 - 02:27 GMT I was gonna say I did a search on this and other sites and found the answer to your same question. Please read some and you will find the answer...
Username: Nikk Post Number: 432 Registered: Sep-06
Wednesday, October 18, 2006 - 02:27 GMT Of course, from de IF OUTPUT of the first receiver to the IF INPUT of the second one
Username: Tariqic Post Number: 82 Registered: May-06
Wednesday, October 18, 2006 - 11:29 GMT The "If Output" scenario will not work because the receivers are in different rooms and also, don't think I will be able to watch different programming from the two receivers.
