New member Username: Jack786Post Number: 1 Registered: Oct-06 | Hello folks, I just bought a new Pansat 2700A (IR). Last night I loaded the bin which i got from pansat website. I assume it's the latest version. during the load it asked me if i wanted to load app file only, channel data only, transfer only. Which one do i select? Also where do I get the latest code to get the south asian channel and Cricket. My dish is pointed at 61.5 I live in connecticut. I'm new to this so any help will be greatly appriacated. Thanks. |
New member Username: Jack786Post Number: 2 Registered: Oct-06 | Can some one please answere. Thanks. |
New member Username: Alishahid24Post Number: 6 Registered: Oct-06 | choose app file only. leave others as it is. all bins are good. 274,275,279. Make sure you get the latest keys. its in these forums somewhere. you have to look for it. turn the auto roll off and auto TP off as well. lemme know if that helps |
New member Username: Jack786Post Number: 3 Registered: Oct-06 | Thankf or the reply. the file i had is pansat2700a_060526_115_api.bin. Is this one of 274,275,279? Thanks again. |
New member Username: AgalyaPost Number: 2 Registered: Feb-05 | if u have pointed to 61.5 then choose echo star 3 and do blind scan first check the signal - for new bin - select app file only. make sure com setting is correct enjoy!!!! |
New member Username: Jack786Post Number: 4 Registered: Oct-06 | thanks buddy. Do i need to replace the LNB? Currently it's the one supplied by Dishnetwork. And do you know the latest key, i get all confused by this. there's like 100 posts on it with everybody posting different key, which one will i need? Thanks. |
Silver Member Username: Hawaiian_timeHawaii Post Number: 651 Registered: Apr-06 | jack, the 060526 part of the bin you have is the date. It is an old bin. You should look for the X-87BL_061011_279 bin, which has a working auto roll. |
New member Username: Jack786Post Number: 6 Registered: Oct-06 | where do i get this updated bin from? Thanks. |
Silver Member Username: Hawaiian_timeHawaii Post Number: 652 Registered: Apr-06 | Sorry jack, the bin you have is the factory bin. Load that first, then the 279 bin. |
Silver Member Username: Hawaiian_timeHawaii Post Number: 653 Registered: Apr-06 | dsscommunity.c@m has it |
New member Username: Jack786Post Number: 8 Registered: Oct-06 | I've already loaded the factory bin. dsscommunity is blocked site from my work, so i'll have to get it once i get home. |
Silver Member Username: Hawaiian_timeHawaii Post Number: 654 Registered: Apr-06 | I prefer future-fta.inf@, need to register first though. replace @ with o |
New member Username: Jack786Post Number: 9 Registered: Oct-06 | lol, that's blocked too. |
Silver Member Username: Hawaiian_timeHawaii Post Number: 655 Registered: Apr-06 | wow, at least your company lets you come here! lol |
New member Username: Jack786Post Number: 10 Registered: Oct-06 | tell me about it, by the way, i really do appreciate you guys trying to help me out. hopefully i'll be able to ge the latest bin at home. what do i need to do next? |
Silver Member Username: OscPUERTO RICO Post Number: 112 Registered: Sep-06 | THIS IS IT JACK |
Bronze Member Username: Jack786Post Number: 11 Registered: Oct-06 | thanks Buddy, I'll check it out once i get home. |
