New member Username: TggPost Number: 1 Registered: Oct-06 | I hope this helps. My receiver is up and running no problems. If you can enter the keys manually, GREAT. Some folks are remote control/manual key entry challanged. If this is you, download the file, unzip, open loader program, select file, and load as you would a program, wait for rec. to reset/boot...Watch T.V. Keep On Smiling...
