Bronze Member Username: Lroy
Post Number: 100 Registered: Aug-06
Posted on Can a standard LND @ Lo frequency 11.250GHz works on AMC4 Ku and Echo 9 121w, if not which is the correct LNB????? |
Silver Member Username: Nikk
Post Number: 377 Registered: Sep-06
Posted on Iroy.... You need a Linear LNB for Echo 9....... |
Silver Member Username: Lroy
Post Number: 101 Registered: Aug-06
Posted on What is the Lo. Freq. of a linear LNB for Echo9 and AMC4........ |
Post Number: 381 Registered: Sep-06
Posted on You can see all that at www.lyngsat*.com just take out the * at the link... |
