Can a kx400.2 be bridged at 2 ohms
Username: Rickross
Post Number: 9
it says its 400 x 1 bridged at 4 ohms but would it be able to run at 2 ohms?
Username: 420alldaylong
Post Number: 510
Yes 2ohm stereo
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2856
400x1 at 2 ohms= i don't think so, i think is 4 ohm stable bridged.
Username: Ctmike
Ct.
Post Number: 1951
pg xenon 400.1 would work well (which i happen to have one for sale:-))
Username: Alias747
MN
Post Number: 1442
Yes Juliob is right, that amp isn't 1 ohm stable. Take a look at Mikes amp. Or give us a budget and voice coil configuration and power handelign of your subs and we'll help ya out.
Username: Freezeman_7
Lindsay, Oklahoma
Post Number: 373
yeah, im pretty sure that all amps are bridged at 4 ohms. maybe not, but all the ones ive owned, if they were bridgable, it had to be at 4 ohms
Username: Juliob
Post Number: 2864
i'd go with a PG xenon 400.1
Username: Makmillion
MN United States
Post Number: 1110
If the amp is 1 ohm stable stereo, it is most likely 2 ohm bridgable.
Your amp, however, is not 1 ohm stable. So it is 4 ohm bridgable.
Post Number: 517
Chase
Not all amps can be bridged at 4ohm.
For Example My Rockford T3002
50x2 at 4ohm stereo
100x2 at 2ohm stereo
150x2 at 1ohm stereo
300x1 at 2ohm mono bridged
This amp Is Massively Underrated
Lindsay, Oklahoma
Post Number: 374
i know, but like i said, the amps i had were all bridgealbe to four ohms only. and i also said pretty sure. amps arent really my deal. im more of a sub guy. im learnin with amps tho
Username: Mitymouse
Post Number: 14
If you're talking about running subs, go with a class D monoblock.
Username: Tjmutlow
Post Number: 2939
the majority of 2 channel amps are only 4 ohm bridged, there are a few that is 2 ohm stable, not many though.
Username: Rickross
Post Number: 17
how much r u sellin the xenon for?
Username: Rickross
Post Number: 18
im looking for any amp to push my 4th cvr right now i have 2 on a mb quart raa1000 and 1 on a kx400.1 and i just bought a 4th one and i just need a amp to push it i dont care if its 2 channel or mono just has to do around 400 watts
Username: Killer44
Ontario Canada
Post Number: 723
why not sell ur kx 400.1 and then buy another raa1000 to run the other 2...jsut a thought instead of having to run 4 speperate amps...all putting out different power...
Lindsay, Oklahoma
Post Number: 376
thank you ty, see i wasnt that far off
