Problem with uploading bin
Username: Zainmalik
Calgary, Alberta Canada
Post Number: 39
i have a recive tht call panast 2500a and i got the wire but when ever i tried it says tht write failed any help pwill plzz
and one more question do i need anew bin for tht to see chanels or i justneed to change the bin thxxxxx
Username: Starz98
Post Number: 18
put in the platinum vie$tat bin in my extreme vie$tat. Now I am having problems. What I have done so far is redownload factory bin, redownload the before last bin and downloaded the lastest autoroll bin for view$tat extreme. I am getting a good signal, the guide is showing the programs, but I am not getting a picture, except for the free channels. Any suggestions?
I have also just tried putting in the new keys, same thing no picture.
yea, I know I fucked it up, lol
Username: Labait
Edmonton, Alberta Canada
Post Number: 35
more than likely you will need a new updated bin 278 is most recent...believe in the 2500a in user setup there is an option for uploading that has to be turned to
Username: Labait
Post Number: 36
only thing i can suggest at this moment Starz is making sure auto is off and double checking the 00 and 01 codes are correct
Dishnet Keys, Provider 0101:
Key0: 0C FA 39 73 91 5F F5 54 E9 56 1C 42 8B 7A CA B2
Key1: 2F 1F 8F 26 51 18 BA 33 5F 95 1C DB EE 18 68 D9 (Active)
Bev Keys, Provider 0901:
key0: C9 BB A9 83 ED AE 55 D6 62 DE 45 C1 EF 14 B5 D3 (active)
Key1: 99 AB 62 AB 10 07 1C E8 A2 6B 2A 2A B5 B0 9C 57
Username: Starz98
Post Number: 19
Ok thanks for the help Robert
Username: Starz98
Post Number: 21
I tried that and I still am having the same problem, no picture with program listed. Any other suggestions?
Username: Nikk
Post Number: 364
Malikzain....
For any 2500 clone or original you need a RS232 "Straight" cable....check if you have that one, maybe you have a RS232C that one will not work, if you wat to use it go to radio shack and get a "Null modem adapter" by $10 and plug it into you existing cable, that must work...
