Help pansat no power
Username: Dghumman
Ontario Canada
Post Number: 53
i have a pansat 2700 and i downloaded the latest file and watched all the channels for 2 days and suddenly while i was watching the power went off i tried to unplug and plug back but it remains blank.
can someone help me fix this problem i cheked the fuse also thats okay too.
Username: Dghumman
Ontario Canada
Post Number: 54
hello guys can someone help e and tell me can this be repaired or not
Username: Jojogun
Fairfield, CA United States
Post Number: 193
All I can think of is try reloading the bin.
Username: Dude123
Post Number: 267
did you check if your auto roll if OFF make sure only key code in ON turn off everything else and put in the following keys your should get the channels back:
Updated: Saturday, October 7 2006
Dishnet Keys, Provider 0101:
Key0: 0C FA 39 73 91 5F F5 54 E9 56 1C 42 8B 7A CA B2 (active)
Key1: 66 B9 F6 53 70 ED 2A 5B 31 D5 59 D2 9F 1C 52 63
Bev Keys, Provider 0901:
key0: C9 BB A9 83 ED AE 55 D6 62 DE 45 C1 EF 14 B5 D3 (active)
Key1: 5B 14 37 7E 7A 73 3C 38 C0 68 D5 A9 57 C2 13 D5
Username: Mc_sunny
Post Number: 449
if it dead...no power or light show on the unit screen. look for factory bin...reload the factory bin...
Username: Dghumman
Ontario Canada
Post Number: 55
where will i get the factory bin and will it reload without no powe no light on the unit screen
Username: Mc_sunny
Post Number: 450
First try to do Factory flash..if it won't let u then u have to jtag it..
Here it is click on this link
Pansat 2700A original FTA factory flash
http://www.dssevolution.com/forums/showthread.php?t=43925
Username: Dghumman
Ontario Canada
Post Number: 56
i tried factory flash but its completely dead now what shoud i do , i dont know what is jtag is and how to do it and will it fix the problem that there is no power and no light on the box its completely dead
Username: Nikk
Post Number: 378
First of all you need to check the basics....
Maybe there were a peak on the power line and your receiver just got a blown fuse, have you checked that first????
The only problem is that you will have to take the cover of your receiver out and take a look at the inside..
If the receiver is off there is no way on which you can download any bin on it...
