Bronze Member Username: ShenanigansPost Number: 26 Registered: Sep-06 | Does anyone know what happened to Scream? Most everything else seems to working fine for me including ppv, vEnUs. I'm thinking it may have moved from it's location at 12501 4898 4899 since I'm seeing the 'scrambled or bad channel' message. I did a tp scan on 12501. SCRM shows up in the scan results at the same parameters as before with the same message. I was just wondering if anyone already knows where it moved to before I begin an extensive search for it... Or if the problem may be on my end.... Or if it might be temporarily unavailable. Thanks. |
Bronze Member Username: Miguel03Tucson Post Number: 67 Registered: May-06 | SCRM is on 12501, Tp 20, Channel 332. I just checked and it is working. You might want to save this site for future use, comes in handy for DN and Bev. Change * to and a. http://www.lyngs*t.com/packages/expressvu1.html |
Bronze Member Username: ShenanigansPost Number: 27 Registered: Sep-06 | Thanks for the response, Miguel. I've been using Lyngsat for many years now. Sometimes they can be a little slow in getting the info updated and I thought they might not have gotten the info yet. After you said Scream was working fine in the same location for you, I tried something I had overlooked. I powered off then back on and it popped right in. Sometimes I over complicate things for myself by forgetting the simplest solutions. Thanks again. |
