Gold Member Username: Troy81Tavernier, Fl Us Post Number: 1224 Registered: Mar-06 | how do you take the stock HU out of an '00 expedition**** |
Gold Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 1951 Registered: Apr-06 | u either pop off the trim around it and take out the screws..or just pop it out... try to look for screws and allso if its not budging after u pull it pretty hard dont keep pulling..tht means thier is a scrw holding it... |
Silver Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 511 Registered: Jul-06 | You may need that dual pin tool that ford uses for their theft deterrant device.Look on the front of the head unit you might see 2 pinholes on the left and 2 pinholes on the right if so...you need a tool that ford uses. |
Gold Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 1953 Registered: Apr-06 | oh yes i have herd of those..they look like a U-shaped tool..im sure thier only like 4 bucks... go to advanced autoparts... ask them for the book about ur car tht gives u step by step on just about every thing u can do to ur car.... itll give u a wiring diagram and everthhing so im sure it tells u how to pop ur trim |
Gold Member Username: Troy81Tavernier, Fl Us Post Number: 1225 Registered: Mar-06 | is there any place to get that tool? |
Gold Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 1954 Registered: Apr-06 | ask at advanced autoparts or autozone pep-boys will have it for sure |
Gold Member Username: JmloughreyFarmington, CT Post Number: 1619 Registered: Jul-04 | if you're looking to get the radio popped out, try going down to your local circuit city, offer the installer there like $5 cash and chances are fairly good he'd be more then happy to pop it out for ya. I've made a good $100 cash in pocket just opping out ford/vw/audi radios this passed summer |
Silver Member Username: RenegadesrunLafayette, IN US Post Number: 325 Registered: Oct-04 | http://www.installdr.com/InstallDocs/FLM/PDF/356033.pdf#search=%22expedition%20s tereo%20removal%22 Google > u. |
Gold Member Username: MakmillionMN United States Post Number: 1108 Registered: Apr-06 | Walmart sells the took for >$4.00 |
Gold Member Username: MakmillionMN United States Post Number: 1109 Registered: Apr-06 | Walmart sells the tool for >$4.00 |
Silver Member Username: RenegadesrunLafayette, IN US Post Number: 328 Registered: Oct-04 | We have "tools" here.....for FREE!! heh! |
Silver Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 513 Registered: Jul-06 | I don't think anyone understood that^ but me ![]() |
Silver Member Username: OglejustIl Us Post Number: 221 Registered: Aug-06 | dude i took a radio out of a ford windstar the other day, i took a metal clothes hangar and cut the corners off. they r already u's. just stick them in and push the tops of the u to the outside and pull. it worked for me! good luck |
Gold Member Username: Troy81Tavernier, Fl Us Post Number: 1226 Registered: Mar-06 | ok, im gonna try tomarrow, im more worried about the plastic cosmetic cover thing. idk how to get that off, i saw in the thing that it just pulls off but it didnt seem to just pull off, i dont have it right here to try so ill have to wait till tomarrow i guess, thanks all yall to help out one of your brothas |
Silver Member Username: Dsmith07Post Number: 148 Registered: Jun-06 | i took the cd player out of my old car ( 95 lumina) unscrew 2 screws and pop the dash out then unscrew the head unit...easy as pie. |
Gold Member Username: Troy81Tavernier, Fl Us Post Number: 1228 Registered: Mar-06 | ummm, different car... wtf? ive done ALOT of other cars with no problem but this got me stumped and i found out why ^^^^ |
Silver Member Username: RideredderCornell, IL USA Post Number: 531 Registered: Sep-05 | The tools are free is right. A hanger works great if you need the U-shaped tool. Just cut two lengths off of the hanger and bend them into shape. Worked great when I took a stock HU out of an Explorer. |
Gold Member Username: MakmillionMN United States Post Number: 1113 Registered: Apr-06 | I suppose im the only installer that likes to have the proper tools around "just in case" ![]() |
