Problems with the new pansat bin
Username: Chicas
London, Ontario Canada
Post Number: 20
i downloade bin 278 and 279 and all my channel disappeared, then I did a blind scan and get no transponders or channel. does any body no why? I need some help. It said my quality is o%. When By the way my receiver is pansat 2700a. when I put digiwave it works the signal strenth of 0%. I need your help;
Username: Hawaiian_time
Hawaii
Post Number: 644
You can try downloading the factory bin first and then the latest bin.
Username: Smarcus76
Post Number: 253
how does the signal read???
Hawaii
Post Number: 645
It's not raining by any chance over there Antonio?
Username: Chicas
Post Number: 21
no is not raining
Username: Chicas
Post Number: 22
I have no switch hooked up because I get no signal. It is connected directly to my receiver.
My digiwave works and get some channels but my pansat 2700a doesnt't. The level on the" unlock bar reads 30% and 0% quality. any know what could be the problem. and where can I get the factory bin?
Hawaii
Post Number: 646
Most of the sites that you get bins from should also have the factory bin. Or go to Future-fta
