New member Username: TitleistPost Number: 3 Registered: Feb-06 | What are the best speakers I could get for 1200.00 or less. I want the speakers to be small so I can hide them in the corners. Also, anyone tried or heard the Yamaha ysp 800..Maybe that would be a possibility if the surround sound is somewhat similiar |
Gold Member Username: Project6Post Number: 5910 Registered: Dec-03 | Try Orb Audio. |
Bronze Member Username: N8d1Baltimore Post Number: 14 Registered: Jan-06 | I have a Mirage Nanosat/S12 5.1 setup that I am very happy with. A bit larger that the Orb but not bad. Got the whole set for $900 shipped from Vanns. |
Bronze Member Username: N8d1Baltimore Post Number: 29 Registered: Jan-06 | Yet another post I see that I put down the wrong speaker name. My setup is with the Mirage Microsats and the S12, not the Nanosats. They are the next step up from the Nanosats. |
New member Username: DrdoomPost Number: 2 Registered: Aug-06 | Infinity TSS 450 5.1 rocks the house and you can get them for less then $400, check out the reviews or you can come over my place if you live anywhere near NYC. |
Silver Member Username: HawkHighlands Ranch, CO USA Post Number: 976 Registered: Dec-03 | I still believe the best set is the KEF 2005.2 system. Small, extremely attractive, and they sound much better than anything I have heard in that size speaker. Has a better sub than any other 5.1 system I have heard for less than $2K. Cost is about $999 . . . |
Bronze Member Username: DarthThe woodlands Post Number: 98 Registered: Aug-05 | This is anoher option...very nice system http://cgi.ebay.com/Cinema-Vision-5-1-Home-theater-system_W0QQitemZ150033155655Q QihZ005QQcategoryZ94912QQcmdZViewItem |
Silver Member Username: HawkHighlands Ranch, CO USA Post Number: 984 Registered: Dec-03 | Vader: Your ID says you are in "The Woodlands". Is that near Houston? Just wondering. |
New member Username: SilverlakePost Number: 3 Registered: Oct-06 | Athena - they really sound this good!!!! I have the SF-2's as fronts (I know not surrounds) the C-1, PS-400W sub and AS-R1's as my rears. And they will not break the bank. -SilverLake |
