Username: Night_mirage AmmanJordan
Post Number: 519 Registered: Jan-06
Tuesday, October 10, 2006 - 20:33 GMT HEEEY Finally i bought today morning 150amp altarnator . 150 is the bigest 4 mercedes E-class . I could n't find more , I was thinking about 200Amp I have now zx1000.1 and 2512 DD's subwoofer . I did n't buy more than 1000 RMS cuz my old alt was 90 amp , And I have three Xenon , So more than 1000 would be Prob . but 4 now i want to put more than 1000RMS How many watts can i Do ? 1500 ?? 2000 ?? And what a good amplifier for two 2512 DD's .. I will upload a pic 4 my alt , Tomorrow ..
Username: Juliob Santo DomingoDominican Re...
Post Number: 2834 Registered: Dec-05
Tuesday, October 10, 2006 - 20:35 GMT nice
Post Number: 520 Registered: Jan-06
Tuesday, October 10, 2006 - 20:39 GMT Juliob , Thanks , But i want more than NICE hehehe Does 150Amp . consider as HO ?? or 200A and more ? I want now an amplifier ?
Username: Adddisorder West palm,
Florida
Post Number: 1127 Registered: Jan-06
Tuesday, October 10, 2006 - 20:45 GMT well 2000rms class d should pull 200a plus however much your car needs. but sence your amps wont be running at full power most of the time you should be alright if you just put in maybe two batterys.
Post Number: 2838 Registered: Dec-05
Tuesday, October 10, 2006 - 20:46 GMT it is considered as a HO alt. Those subs can handle 1k each but considering your system... you should get a 1000-1200w rms amp, can you tell us the DVC config on those subs
Post Number: 521 Registered: Jan-06
Tuesday, October 10, 2006 - 21:02 GMT dvc 4 ohm I want 1 ohm amplifier And i thing 1500 would be fine !! Do i need battery
Post Number: 2848 Registered: Dec-05
Tuesday, October 10, 2006 - 21:10 GMT you need batteries, at least 1 yellow top and a red top. Night what's your budget for an amp??
Post Number: 522 Registered: Jan-06
Tuesday, October 10, 2006 - 21:22 GMT emmmm , we don't have any yellow top or red top batteries ..? How many amp the battery .. ?? and budget about 350 cuz there is another 150$ 4 shipping ?
Post Number: 524 Registered: Jan-06
Tuesday, October 10, 2006 - 21:25 GMT ops , sorry i ment 450$ SORRY
Post Number: 526 Registered: Jan-06
Tuesday, October 10, 2006 - 21:35 GMT how is Soundstream PCA1500D GOOD ?? Its cheap , why ? or just old soundstream good ?? as us ampifier
Post Number: 2849 Registered: Dec-05
Tuesday, October 10, 2006 - 22:04 GMT soundstream is good, old soundstream was Great. The PCA will do the job. You told me they don't sell yellow tops or red tops, that's hard man, maybe because of the name you can't find them, they're different from acid batteries.
Florida
Post Number: 1144 Registered: Jan-06
Tuesday, October 10, 2006 - 22:05 GMT i think those are supposed to be pretty good. us amps are great i think the MD2 puts out power in the range you are looking for also kicker zx1500 i wouldnt get a yellow top anyway. you should look for kinetic or stinger/ odessy
Post Number: 527 Registered: Jan-06
Tuesday, October 10, 2006 - 22:14 GMT Juliob , I don't think with 1500 , i will need a Battery . And New SS And New US . Are very Cheap . And i heard they 're Not that Much comparing by OLD STUFF . MAT ZX1500 Stable @ 2 ohm .. Will n't FIT .
Florida
Post Number: 1152 Registered: Jan-06
Tuesday, October 10, 2006 - 22:26 GMT my bad, id definatly look into us amps over SS. id look into puting a new battery in, but see how yours holds up first, hopefully you be ok if your only running 1500rms oh also the kicker kx1200.1 puts out 1400-1500 at 14.4v
Post Number: 2853 Registered: Dec-05
Tuesday, October 10, 2006 - 22:27 GMT Mat he needs 1000w+ at 1 ohm. He owns a zx 1000.1 Night US amps are good, any amp can put 1000w rms at 1 ohm. The SS is good, and maybe you don't need those yellow tops if you're not going to bump with your car off. But you should get a good battery.
Post Number: 529 Registered: Jan-06
Tuesday, October 10, 2006 - 22:58 GMT emmmm , I have kx1200.1 If u remember Juliob , But I want more . It puts 1440RMS What do u think ? And i have 90Amp Battery (New one) Do i need another one ?
Post Number: 530 Registered: Jan-06
Tuesday, October 10, 2006 - 23:01 GMT emmmm , I have kx1200.1 If u remember Juliob , But I want more . It puts 1440RMS What do u think ? And i have 90Amp Battery (New one) Do i need another one ?
Post Number: 531 Registered: Jan-06
Tuesday, October 10, 2006 - 23:06 GMT emmmm , I have kx1200.1 If u remember Juliob , But I want more . It puts 1440RMS What do u think ? And i have 90Amp Battery (New one) Do i need another one ?
Post Number: 532 Registered: Jan-06
Tuesday, October 10, 2006 - 23:15 GMT opssssssssssy I thought its Not ADDED WOOOW three times . BAD FORUM ..
Post Number: 2858 Registered: Dec-05
Tuesday, October 10, 2006 - 23:17 GMT damn 3 posts hehe! install the KX. If you want you can get a 2k rms but your alt isn't going to do the job. I think 750w rms to each sub is fine, their site says 500w at least.
