hi all , i have a cooltec, a co0lsat clone. the problem is that i dont have the blind scan option. While my cousin has the same machine with the same software and hardware version but he has the blind scan option, how can i get blind scan on mine? is it a matter of factory bin? if so where can i get it?thanks
the problem is that i am not getting some channals with just auto scan , and when i try to add the frequency of the specified channal , it says invalid , but it actually works on the reciever with blind scan
Do a factory flassh on your receiver. h**p://forums.f2atv.com/showthread.php?t=21969 change ** to tt and register there for free. Then download this bin and flash it into your box. It will be as good as buying a NEW n FRESH box.
