New member Username: ChicomanPost Number: 1 Registered: Oct-06 | If someone would be kind enough to get me the how to on this Fortec Lifetime Ultra it would be verry much appreciated. I believe it was last fixed in March somtime. Thank you. |
Silver Member Username: Mc_sunnyPost Number: 431 Registered: Feb-06 | There has been alot of great guides and info posted here,, by many different people !!!! everyone should spend time reading and learning there recievers,, the key changes will allways happen,, bins will need to be changed,,and so on !!! all of these same questions are asked everytime !!! and the answers are posted,, and posted again,, and again ,,, please do some research ,,, we will help ,, but ya need to learn the basics !!!! |
New member Username: ChicomanPost Number: 2 Registered: Oct-06 | Hey Sunny, I have been reading for about 2 hours and could not find a guide on how to with the Fortec. I have a different receiver and have loaded keys for a while now but couldn't find any info on this other one other than that it should be the same as the pansat 2500. Been looking for the pansat 2500 and not a post I could find on instruction. I have been following this forum for a while now and know better than to ask before reading but as I say just couldn't find the info I need it. |
Silver Member Username: Mc_sunnyPost Number: 438 Registered: Feb-06 | How to change the NAGRA2 Key codes (for Fortec Lifetime Ultra only) 1- Press Menu button on your remote control 2- Press right arrow key 2 times Channel Edit 3- Press down arrow key button 2 times, press OK (Code) enter 1010 4- Press the down arrow key to Set Default Key, click OK 5- Press the up arrow key to Nagravision click OK 6- On your top left you should see Nagravision-1...if not, then you've got the wrong BIN version. 7- Press right arrow key until you see Dish Network on top 8- Press the down arrow key once to Key Number 9- Press right arrow key 2 times the from Key Number 00 - 01 - 00 ( Now take notice that on your top left you should see Nagravision-2 now ) 10- Then press DOWN button key to change the keys manually on Key Number 00 11- Enter new Keycode, do the same procedure to enter the the keys on Key Number 01 Note: Satellite Providers changes the stream key codes unpredictably, (Note: remote control key letters equivalent) A = Sat, B = i, C = Tv/Radio, D = Pause, E = Audio (speaker), F = EPG 12- Check and make sure that you got all the keys....Press OK to store (save) 13- Press EXIT key 3 times to exit to the channels. Note: If you accidentally lock the KEYCODE (OFF) use this default password 1668 |
Silver Member Username: Mc_sunnyPost Number: 439 Registered: Feb-06 | Here is how to Load bin into your fortec.. Blacklist loader guide.. -The first thing you need to do is to disconnect your stb from the lnb cable. Turn off the switch on the back of the stb. Connect your straight thru serial cable from your computer to the stb. Load Blacklist Loader. Make sure you specify the correct port and then browse for the correct bin.Right now there in nothing for fortec.. Once you have everything ready, turn on the switch on the back of stb. As soon as the first bar appears on the stb, click the load button in BL Loader. The bin should start loading at this point. It will take a couple of minutes. Don't touch anything until the process is complete, your STB should then finish booting and display a channel number or if not previously set up it will show "on". You can then turn it off and disconnect the serial cable and reconnect to your lnb and tv. Remember, timing is critical in the process, if you don't get it right the first time, keep trying. You will eventualy get it right |
Silver Member Username: Mc_sunnyPost Number: 440 Registered: Feb-06 | This link will give u the latest file..Right now 280t bin is working for fortec ultra https://www.ecoustics.com/electronics/forum/home-video/275159.html |
New member Username: ChicomanPost Number: 3 Registered: Oct-06 | Thank you so very much Sunny. I really appreciate all the help. |
Silver Member Username: Mc_sunnyPost Number: 443 Registered: Feb-06 | np...Good Luck |
New member Username: Alex_matosArecibo, Puerto rico Post Number: 1 Registered: Jun-06 | Hi everybody, My name is ALex, i'm a little desperate for while. I have a Fortec Ultra, never work with it, but I worked with Digiwave and Pansat. My problem is that I bought a cable RS-232, not null, should be straight, I download the blacklist loader and the bin, for Fortec Lifetime Ultra, everytime I try to download the bin into the Fortec I received the message "write Failed" retry, and get nothing plus the Keys in the Fortec are 16 digits, compare to the other ones that are 32 digits keys for pansat and digiwave, can somebody be kind to explain to me what I'm doing wrong and how to fixed it , I want to learn and I'll be really grateful. ALex |
Bronze Member Username: FidarahmanPost Number: 58 Registered: Nov-05 | Follow the steps above given by Mc sunny |
