Will there be a p5 hack
Username: Moneybags180
Post Number: 7
when will there be a p5 hack
dupont24
there are no hacks at present...there are work arounds...don't even ask cuz i can't tell you how they work.I would only be guessing....but as for a hack for the p5/d1 yes i believe it will come soon...maybe within a month maybe sooner.
will they kill the p4 card at the same time as the hu or some time later
Jimmy Beam
The P4 will be around for at least a year. Probably longer then that.
how can i get free card from dave when i live in bahamas. i will like to have a three room system that come with 3ird and i dont no if it come with 3 cardsneed help there. if i give us adress do i let them install and then take down and bring to bahamas? and can those cards be progam when hack come out.thanks bahamas ninja
How can you get 2 rom receivers without registration with DTV.
stick boy
is it better to purchase the p4 or the p5
