Help!!!@@
Username: Rikarddo
Post Number: 71
hi. is it possible i can get into my neighbors wireless internet connection? i tried but its protected by that wep thing
Username: Rikarddo
Post Number: 72
any help!!!!!!!!!!!!
Username: Nikk
Post Number: 927
There is nothing for you to do unless talking with your neighbor and ask him to grant you access, otherwise just start talking to them and ask for the username and password....
Username: Cugine
San Jose, CA USA
Post Number: 15
It is actually fairly easy to break WEP authentication. FBI demonstrated it a few years back at a blackhat event. It took them about 3 minutes.
Just remember it is considered illegal to use a wireless connection that has authentication and if they know what they are doing they can tell if you are on it and even steal your data ;).
Username: Donnie1973
Tennessee
Post Number: 532
yeah, if they look in the status- users, your computer name would be there...
Need to Register?
Forgot Password?
Enable HTML code in message
