Keys not working
Username: Nit115
I have pansat 3500sd and the keys are not working. I have put them in a couple of times and nothing. All i get is either a blank screen or "scrambled or bad channel". I got the keys a couple of days ago and they worked fine for bout day. Now i get nothing. I have tried updating the bin - turned autoroll off and on doesn't work with either. Any help would be greatly appreciated.
How can i tell which key is active?
Thanks
Username: Nit115
DOnt worry - i switched to another satellite and started working.
Username: Minn_rock
Post Number: 422
Ni My..the keys is in this link on the right hand side.
http://www.dssevolution.com/?
turn off autoroll,enter new keys,if still no picture turn your box off from the back of your box than turn it back on..and u will know which keys is actice they tell u...
Username: Minn_rock
Post Number: 423
LOL..I LOST 3 MINUTES FOR NOTHING..
