HOW TO ENTER THE KEYS
Username: Austin_r
how do i enter keys and were am i supposed to be for viewsat dishnetwork
Username: Mc_sunny
Post Number: 430
You can do it two ways:
1. Use a shortened LOAD & GO to load ONLY latest opkey file...
2. use your REMOTE control... Below is a ficticious example when you already have the KEYs to update KEYS using your REMOTE CONTROL.
Have a Computer "opkey" File? Use the Modified "LOAD & GO" EASY SETUP Procedure Below:
1. D/L the latest opkey file (usually a zip) and UNzip; remember where the unzipped file is located on your computer.
2. Power "OFF" your ViewSat and hook up the NULL MODEM CABLE between your PC and your ViewSat
3. Open LOADER2, Click "Open Files" and navigate to the UNzipped "opkey.hex" file you wish to load
4. Click on "opkey.hex" file and click on "OPEN" to load that file into LOADER2
5. Click on the PC-->STB button and turn "ON" the ViewSat
6. The opkey.hex file will autoload into the ViewSat
WAIT between 15 seconds and 1 minute for the ViewSat to process the new opkey file, install the opkey file, do the housekeeping/cleanup of data necessary and then, the ViewSat will auto-REBOOT.
DO NOT TURN OFF THE VIEWSAT UNTIL IT HAS FINISHED REBOOTING!!!!
If you are connected to a TV, the picture will automatically come on.
If you are NOT connected to a TV, after you are sure the ViewSat has finished the processing/installing/rebooting, you may power "OFF" your ViewSat and connect it back to your TV.
NOTE:
It is NOT necessary to do anything else to your ViewSat other than LOAD & GO the opkey.hex file... no rescanning, no Factory Default, no ANTENNA SETUP... the whole opkey loading and back to Tv should be about a 3 to 6 minute operation.
MANUAL PRETEND Public Key Change by teach (12-04-05)
The PRETEND Public Keys have changed to:
Key 00: AF 98 74 44 1C 65 77 D8
Key 01: AF E3 E1 1D 89 4E 53 45
On the REMOTE CONTROL, you'll be using the 0 through 9 keys for the number you need and...
A = F1
B = F2
C = F3
D = F4
E = "LAST" key (circular arrow key to RIGHT of "0" )
F = "TEXT" key (2 rows ABOVE F4 key on right side of REMOTE)
TO MAKE A MANUAL KEY CHANGE in your ViewSat:
MENU--INSTALLATION--CODE--NAGRA
LEFT arrow until "Dish" displays in the top line and you have at least 4 ROWS of numbers like below. The 4 rows we are most interested in are:
08 xx xx xx xx xx xx xx xx
09 xx xx xx xx xx xx xx xx
88 xx xx xx xx xx xx xx xx
89 xx xx xx xx xx xx xx xx
DOWN arrow until the RED is on "08"
RIGHT arrow x 1 puts you on the "08" line of numbers in the 2nd column
"F1" + "Text" = "AF", RIGHT arrow
"9" + "8" = "98", RIGHT arrow
"7" + "4" = "74", RIGHT arrow
"4" + "4" = "44", RIGHT arrow
"1" + "F3" key = "1C", RIGHT arrow
"6" + "5" = "65", RIGHT arrow
"7" + "7" = "77", RIGHT arrow
"F4" key + "8" = "D8", RIGHT arrow ... finishing the top line.
You should have the highlighted box in the first column of the 2nd row on top of "08"
DOWN arrow x 1 and RIGHT arrow x 1 to the 2nd box in the "09" row
"LAST CHANNEL" key (below "9" key) + "3" = "E3", RIGHT arrow
"LAST CHANNEL" key (below "9" key) + "1" = "E1", RIGHT arrow
"1" + "F4" key = "1D", RIGHT arrow
"8" + "9" = "89", RIGHT arrow
"4" + "LAST CHANNEL" key = "4E", RIGHT arrow
"5" + "3" = "53", RIGHT arrow
"4" + "5" = "45", RIGHT arrow
EXIT, OK ("YES") to save
EXIT to TV screen and watch tv
This puts the PRETEND KEYS into the 08 & 09 KEY lines.
If you need to put KEYS into the 88 & 89 KEY lines... do above and substitute "88" for the "08" line and "89" for the "09" line.
Hope this helps.
Username: Hasmaz
Post Number: 18
Do you have a working keys for BEV?
Username: Johnner
Miami, Florida
Post Number: 790
https://www.ecoustics.com/electronics/forum/home-video/259083.html
Username: Austin_r
Post Number: 7
were do i download the dish version at
