New member Username: Cindyandrickd2Post Number: 9 Registered: Sep-06 | ihave downloaded the loader file. but when i try to down load bin file to box says it is downloading but nothing seams to be happenning. nothing shows up on progress bar. any suggestions? | |
Bronze Member Username: LabaitEdmonton, Alberta Canada Post Number: 19 Registered: Oct-06 | what are the steps your taking... | |
Bronze Member Username: Cindyandrickd2Post Number: 12 Registered: Sep-06 | i downloaded the 274 file for 2700a unzipped it to my documents clicked on the program file got the bin file into program hit download and got nothing | |
Bronze Member Username: LabaitEdmonton, Alberta Canada Post Number: 21 Registered: Oct-06 | i could be doing this wrong as i am new as well, but i know so far it seems to be working. i goto user settings and goto transfer. once its ready i will goto download on pc and i'm seeing transfer and the box resets...seems to be working for me quiet well | |
Bronze Member Username: LabaitEdmonton, Alberta Canada Post Number: 22 Registered: Oct-06 | mind you, i dont have this switch in the back of my box that everyone talks about | |
Bronze Member Username: Cindyandrickd2Post Number: 14 Registered: Sep-06 | user settings?? where do i find that at? is that in the box menu | |
Bronze Member Username: AmtPost Number: 12 Registered: Jun-06 | can any on please hlep me in how to enter key's for pansat 2700a in parentAL CONTROL | |
Bronze Member Username: LabaitEdmonton, Alberta Canada Post Number: 23 Registered: Oct-06 | Parental control access key is at default oooo (zero,zero,zero,zero) ya its in box menu Cindy menu, user settings.. transfer | |
Bronze Member Username: Outlawz_5683Post Number: 25 Registered: Aug-06 | what is STB Model for pansat 2500? | |
Bronze Member Username: Cindyandrickd2Post Number: 15 Registered: Sep-06 | ok i will try that thanks | |
Bronze Member Username: AmtPost Number: 13 Registered: Jun-06 | i did put zero zero zero zero then selected new pass and confirem pass then it goes back to old pin what should i do after that | |
New member Username: ChrisducloPost Number: 3 Registered: Aug-06 | you should enter the pin in the "second pin" not "old pin" then in key oo enter the key and in key o1 enter the other key. press ok to save keys. be sure to turn off dishnet auto roll its not working right now. oh yeah... you really need to only enter the "active key". i get my keys from hashhu*com they are more current or just as current as keyripper or grabber. | |
Bronze Member Username: AmtPost Number: 14 Registered: Jun-06 | there is no second key option i m just getting old pin new pin and confirm pin option how will i get 2nd pin option | |
New member Username: ChrisducloPost Number: 9 Registered: Aug-06 | you have a 2700? | |
Bronze Member Username: AmtPost Number: 15 Registered: Jun-06 | its 2700a or 2700a (IR) | |
Bronze Member Username: AmtPost Number: 16 Registered: Jun-06 | can any please help me there is no second key option i m just getting old pin new pin and confirm pin option how will i get 2nd pin option |
Bronze Member Username: AmtPost Number: 19 Registered: Jun-06 | i did install new bin file Pansat 2700A_060526_115_api |
Silver Member Username: JohnnerMiami, Florida Post Number: 798 Registered: Nov-05 |
Stop posting the same fucking thing everywhere! https://www.ecoustics.com/electronics/forum/home-video/276660.html |
New member Username: SabanaPost Number: 5 Registered: Oct-06 | Dishnet Keys, Provider 0101: 1.-Code 2.-Nagra 3.-Dish 01-01-00 not 00-01-00 oo:the same 08:0C FA 39 73 91 5F F5 54 09:E9 56 1C 42 8B 7A CA B2 (active) 88: 66 B9 F6 53 70 ED 2A 5B 89:31 D5 59 D2 9F 1C 52 63 |
Silver Member Username: NikkPost Number: 340 Registered: Sep-06 | AMT... Go to parental control....there must be a SECONDARY PIN option, right there do 0000 from the remote control after that it will open a new window where all of the Codification options...there should be a option NAGRAVISION 2, is right there where you have to enter the keys... |
Bronze Member Username: AmtPost Number: 21 Registered: Jun-06 | there is not second pin option, can any one tell me is that coz of the bin file i have its : Pansat 2700A_060526_115_api |
New member Username: SabanaPost Number: 6 Registered: Oct-06 | Sorry Mr. MT | |
Silver Member Username: NikkPost Number: 341 Registered: Sep-06 | Using that bin you will not be able to see anything...you need at least the 274 bin...... |
