Cable detail needed for Panset2700A to computer
Username: Czgdbc
what is the cable name should I use to buy the correct one for Panset2700A.
I tried Radio shack RS232C serial cable, female to female , female to male , one of other 9pin serial cable but none of them work. The best I got the "Flash Faild" error or it just hanged on 0% download. I think I am not using the right cable.
I read some post and now get more confuse about stright through, crossover , null modem cable.. Can anyone tell me what is the correct name of the cable and from where I should be able to get it. thx
Username: Fulali
Post Number: 8
It seems you are not using correct communication port. Try different port number in number in your loader programme. Cable required is RS 232 female to female.
Username: Labait
Edmonton, Alberta Canada
cable i bought that works good for me is a file transfer cable twin end db9 & db25 from best buy for about $32 canadian
Username: Czgdbc
thx for the input,
I have tried all 4 ports from com1 to com4 but still have the same error. Any detail about the cable that you have used that works for you. Is it says null modem /serial/ crossover or ?
Username: Labait
serial cable...ive updated my 2700a already with a green light all go dont have to kill the kids results
