Archive through October 06, 2006
Username: Nydas
Post Number: 680
The latest Pansat 2500 CLONESAFE Bin is 280T. It has an EPG fix. The 279T will work, but if you haven't go things going you might as well use the 280T BIN.
https://www.ecoustics.com/electronics/forum/home-video/259083.html#POST880165
Username: Nydas
Post Number: 681
Pansat 2700 CLONESAFE BIN.
http://www.dssrookie.com/forums/b-font-color-cd2626-2700-files-font-b/pansat-c-2 700-275v1-99428.html
Pansat-C 2700 275v1
This is 275 Clone Safe Beta Test
If you can't jtag wait for results
Pansat-C 2700 275v1 Tivo.zip (575.3 KB)
Username: Tyrik
Post Number: 19
Donya u should learn how to gramatically write correct, rather than give ppl advice on reading. Babe....chill out and have a toke lol ;)
Username: Harsirat
Post Number: 7
wat keys do i neeed for the pansat 2500??????????
Username: Donyahelwa
Post Number: 111
Nalin:
How is the channels flipping speed for the 280T?
the 279T seems a little slow.
Strange wording!
But I guess you know what I mean :-)
Username: Nydas
Post Number: 682
People: Keys have NOT changed for over two weeks.
Keys are the same for ALL receivers.
Nagravision 2 is where you put in the keys.
Id for DN is 01 01
Id for BEV is 09 01
Id for Gobecast is 0C 01
McSunny has given useful information about what BEV and DN are up to and he has advised turning off autoroll, if you are having problems. His suggestions are based on sound technical knowledge. Please READ his posts and other posts from people like The One and you will not need to ask.
Post Number: 112
ACE:
Did you offer him anything other than to "chill out"? That would give him some TV!
I though I have smelled something. It turned out to be your azz talking. Listen you've started it. Now you chill out!
Username: Nydas
Post Number: 684
donyahelwa: There is, I beleive an "Electronic war" going on. The receivers are barely able to cope with the slower speed of software (as opposed to speed in hardware chips). The faster the receiver, the less likely you will have problems. Try Mcsunny's suggestion of turning off autoroll.
There are too many receivers out there for me to make more than a general statement.
Look not a gift horse in the mouth.
Username: Mkvl1490
Post Number: 50
I NEED HELP. I DOWNLOADED SUMTHIN AND NOW MY BOX HAVE THIS LINE GOING BACK AND FORTH. I CUT IT OFF FOR BOUT 1 SEC AND ITS STILL DOIN IT. HELP PLEASE
Username: Tyrik
Post Number: 20
lol...u must be a sleezy leb
Username: Mkvl1490
Post Number: 51
i downloaded X-05BL_061003_356Teubx_api off of dsstester*com for epg fix
Post Number: 113
Thx Nalina.
I will give it a try.
Username: Nydas
Post Number: 685
Makeveli: I was speedreading at dssrookie and at dsstester and I think I saw some unsatisfactory reports there on the 356T. Better check out what people are saying at those sites, before trying.
Post Number: 114
Makaveil:
I don't know what did you download. But I can tell you this:
the latest bin for Pansat 2500 is 279 and for Pansat clone/fortec is 279T. Other than that you have to know what is your box called and get the right bin for it.
Username: Nydas
Post Number: 686
Makeveli: What is your receiver? The 356T, I beleive, is for Pansat 3500SD.
Username: Nydas
Post Number: 687
donyahelwa: I have to go now. Could you please guide Makeveli, before he burns his receiver!!!
Username: Mkvl1490
Post Number: 53
how do i get this fixed
Username: Mkvl1490
Post Number: 54
Post Number: 115
ok. I will try by best.
Post Number: 116
Ok.
Mak, this should be very easy.
First, we need to get 279 bin. And do the same thing you did for the other bin you had. Easy!
I prefer to use blacklist STB updater. Get them and try to download it into your box. If you encounter more problems come back; we'll figure it out, hopefully.
Username: Harsirat
Post Number: 10
HI GUYZ.
i have pansat 2500clone and i have uploaded the right bin for it and put in the right keys for it.. bit i am still not getting any channels at all.. EVEN IF I TRY TO DO THE BLIND SCAN.. it says 0 transponders found... wat should i do??? please help me... i haven't had my dish working for like 1 MONTH NOW.... please helppp do i neeed to chnage some kind of frequency settings ???
Post Number: 117
harsirat:
try to do factory reset. And then reload the new bin. Make sure the LNB are corrct.
you should get some channels. The keys are not an issue here. Quality of the signal should be 90% or better, but still you should get some channels. And I hope you did't burn your box.
Mac: this is for pansat, the latest bin.
http://www.freewebs.com/dssnetwork/PansatFiles.htm
Username: Mkvl1490
Post Number: 55
its downloadin rit now
Username: Mkvl1490
Post Number: 56
whoo it stopped. now download X-85BL_061003_280_db_api(N) for epg fix
Post Number: 119
cool. let me know. It should't take more than 3-5 min depending on your box.
Username: Harsirat
Post Number: 12
i have pansat 2500 clone from fortect ultra and if i do a factory reset then would it go back to fortec ultra or would it still remain oansat 2500????
Post Number: 120
I think it should remain the same. But I think your problem, after reading some of ur concerns, is the signal.
I suggest you reload the new bin again correctly and turn off the Auto roll. Then put the new keys.
Resetting the box is a way of starting from a common ground between us.
Username: Harsirat
Post Number: 13
i have tried that... its not working....
Username: Jowhar
Post Number: 47
Vertical and horizontal 0 transponder found what is that mean any one
Post Number: 122
Ok. I think it is a connection issue. Maybe the cables or the setting of the LNBs as I mentioned before. It is not that big deal, but the only one can help you here is you. You have to set the LNBs right; this will eliminate any doubts. Moving the dish also will make you lose signal. The dish has to be directed correctly to the sats.
Check out Mc Sunny's response to you.
Username: Jowhar
Post Number: 48
THank you Donyahelwa.
Post Number: 124
My pleasure. But I guess I did have the chance to help u. Right?
Username: Harsirat
Post Number: 15
i am still not getting any signal....i think i am ahaving the same probl as AAI... WAT SHOULD I DO.. ucuz i am getting teh same response...Vertical and horizontal 0 transponder found ??/ wat does it mean??
Username: Tyrik
Post Number: 21
I need some help....
Username: Tyrik
Post Number: 22
Please...
Post Number: 126
That means you both have no signal to talk about. The dish is not aligned right or there is some connection failure. I'm assuming that.
Username: Tyrik
Post Number: 23
who me ?
Username: Big_rock
United States
Post Number: 12
i have ariza xtreme. no picture,standby download. can anyone advise me how to get some channels?
thanks
Username: Harsirat
Post Number: 17
are any of the indian channels working????? please help me guyz.........
Username: Dude123
Post Number: 217
All the channels should be working at the moment...
Username: Harsirat
Post Number: 18
guz i am not able to watch Echo 3... i am getting "bad or scarmbled channel" error.... wat do i do??
Username: Coldgirl
Post Number: 31
I found out when I had no transponders found, It was because I hooked it back up wrong. Try you cable from you dish to Satellite in or antenna in.
Username: Avest
Bham, AL USA
Mc Sunny, I have coosat4000, I tried to enter N2 key
Nagravision
dish NW
86,24-d2-1e-6d-11-f0-95-1a
86,6f-74-6e-bd-bc-c6-92-54
96,66-b9-f6-53-70-ed-2a-5b
96,31-d5-59-d2-9f-1c-52-63
but still didn't work, please help.
Thank You.
Username: Yfcrurka
Hey Donyahelwa,
I downloaded Black List STB updater. Then, used Black List STB Updater to download new bin to my reciever from PC. Download went fine, but my reciever still not working. All i am getting is GREEN LIGHT OF THE RECIEVER MOVING FORM ONE END TO ANOTHER.
Please help me.
Thanks
Username: Pannu16
Post Number: 199
put new keys, turned off autoroll
Still nothin working
zee cinema is gone too, no locals coming!!!!
help please???
Username: Dude123
Post Number: 218
pannu
leave the auto roll off and put the following key under [01] and see what happens, it might say "wait for picture" let it scan till its done and then see what it does
Username: Dude123
Post Number: 219
SORRY here are the keys
Username: Dude123
Post Number: 220
Try these keys people!!!!
For DishNetwork Nagravision2
Key0: 24 D2 1E 6D 11 F0 95 1A 6F 74 6E BD BC C6 92 54
Key1: 66 B9 F6 53 70 ED 2A 5B 31 D5 59 D2 9F 1C 52 63 (active)
Username: Dude123
Post Number: 221
Bev Keys, Provider 0901:
key0: 4F 11 A4 DB 3E 22 85 78 6D FC 54 38 A4 05 20 A9
key1: 3A BA CD 06 03 CE 6D 97 EC FB 9E 68 D4 5E 21 C6
Username: The_others
The One,
I gave up on my Ariza xtreme. What other receiver do you recommend. I presume viewsat has the better support.
Username: Dude123
Post Number: 222
Viewsat xtreme is the best one out there
Username: Pannu16
Post Number: 200
nothin yet guys??
I ordered my viewsat extreme today??
Is that working or not??
Username: Pannu16
Post Number: 201
i tried putting new keys in there, still nothin
Provider id is 0101 for DN
put keys in 3rd and 4 th line. 1st two lines are same. Nothin is working, turned off autoroll too??
help please???
Username: Nydas
Post Number: 690
The keys posted by The One are the correct keys. They changed today. If you manually input them on your 280T BIN, you get all channels with autoroll on.
Username: Pannu16
Post Number: 206
But nalin i do not have a new bin, all i have is the old bin which was showing locals and zee cinema so that means these keys are not good for me!!!
Username: Nydas
Post Number: 691
New Keys - BIN 277T - Few channels (locals) Zcine
New Keys - BIN 279T - All channels. All international on 61.5
New Keys - BIN 280T - All channels, inc. international on 61.5 and Better EPG if you have 119W
Username: Quicksilver_112
Post Number: 14
any new keys out therefor bev saat cruisers???
Username: Dude123
Post Number: 223
Keys have changed today .... read my post above to update your keys
Username: Mindseye
Post Number: 17
C00ltec4000 bin is out, I already tested and it is working.
C00ltec4000_NORW_131_M1
Site:http://dsstester*.com/files.php?cat=25
remove *
if you need the file let me know.
Username: Randy_jan
i have an ARIZA-700, until last night i had all locals working on DN ON THE OLD BIN ONE LINE KEY
00: 24 D2 1E 6D 11 F0 95 1A
01: 6F 74 6E BD BC C6 92 54
TONIGHT I HAD TO CHANGE THE KEYS TO :
00:66 B9 F6 53 70 ED 2A 5B
01:31 D5 59 D2 9F 1C 52 63
TO GET THE LOCALS ONCE AGAIN WITHOUT ZCINE
Username: Randy_jan
The One : thanks for the active keys , your contributions to the forum are great
I still want to get internationals so i have to get the null-F/F cable this weekend to update.still talking about the ariza-700,do you have full info about the new BIN, LOADER AND THE HOW TO PROCESS, I'm new in the field so please enlight me , thanks in advance
Username: Saru4u
hi i have a pansat 2700a. but i cant load a bin on it, can someone tell me the loader, bin, and steps how to do it. i have loaded bin on fortec lifetime but it doesn't seem to work the same way with pansat. my problem is that the download never starts with my pansat. explain when is the right time to press download on the computer, is it when the led light goes from left to right(tried didn't work) or after led light display's ON and the channel number comes on (the download just stays at 0% and never moves forward)
anybody please help.
Username: Flipside3
Surrey
TO EVERYONE ON THIS FORUM
FOR ABOUT 2 MONTHS NOW THE ONLY CHANNELS THAT HAVE BEEN WORKING ON MY SATTALITE WERE "ALL" OF THE CHANNELS THAT START WITH THE LETTER K AND ZCINE THATS IT NOTHING ELSE IN ECHO 1.2 OR ANY OTHER SATTELITE - i have a Ariza 700 i see here that im not the only one begining to hate ariza but if anyone finds the DN keys man i say post em up as soon as you can
Username: Flipside3
Surrey
RAY JAN are you having any channels available to you right now ??
Username: Minn_rock
Post Number: 388
1.did u got the right bin???
2.extract the files first.
3.need the right cable.
4.did u set the com port on your loader right???
5.turn off your PS from the back,press download on your PC than turn your PS back on..
Username: Randy_jan
robby: yes i have locals on echo 1.2
Username: Minn_rock
Post Number: 389
joe that is for you up there..
Username: Minn_rock
Post Number: 390
robby your ariza 700 are working now all channels are back,go here get the bin and load it to your box..this is the bin u gone get...
Ariza 700 Fix AA-1_H20060927_280
http://www.dssevolution.com/?
Username: Lakers123
i got a bin from somewhere downloaded it it got rid of my echostar package of ma sat list and no chanel is working the cod i have on there is
I want to know where i can get a bin and also have echostar
someone plz help thank you
Username: Lakers123
i forgot to mension i have pansat 3500 some one plz help thank you
Username: Minn_rock
Post Number: 392
john this is the bin..X-05BL_061003_356eubx_api.zip
loader..X-05BL Loader v3[1].40 [X-05BL].zip
register free..
Username: Pocket7vens
can someone help me plz got cs 6000 have bin 130 changed keys over autoroll is off and still nothing do i need to put bin 131 in
Username: Dude123
Post Number: 224
ray jan
there is a working bin out there for Ariza 700, and if you want me to send you the loader post your email
Username: U2guess
Hi The One,
I m trying to download the new ariza 700 bin file to my receiver, but for some reason it won't and just says "the flash update failed". All i see on the receiver is the "ON" sign. even after rebooting it is the same. nothing beyond the "ON" sign. I wonder what could be the problem
Can anyone please help me. I have i have not burnt my receiver.
Thanx
Username: 18_volts_baby
Post Number: 17
Information free Help on FTA COMPUTERS AND MORE!
Come and Join a GREAT! Forum
Completely Free Membership
Fully Working Bins for top receivers
LIVE CHAT FOR QUICK KEYS
LOG ON AND REGISTER NOW!
http://electronicguru.net
Username: Dude123
Post Number: 226
sunil s.
make sure you are using the right com port snd the right bin file Ariza 700 Fix AA-1_H20060927_280
Username: U2guess
The one
I m downloading the bin file "AA-1_H20060927_280EU(N)_api.
Now truly speaking, i had downloaded this same file a week agao and every thing wokrd just fine untill last night. I was trying to delete the channels, as i wanted to rescan the channels, but for some reason the receiver will reboot itself and then i would see all the channels again. All it kept doing the same. i saw some weird number on the receiver led "A104 or something like that. and then suddenly after a while all i got left on the receiver led screen "ON" sign, which is still the case. No effect of the remote control too on it. Thats why i thought i might do the factory reset by flashing it with the factory resetting bin. But then it gives the message "model does not "
Can you please solve my this delimma.
Appreciate your reponse to my query, and than you in advance
Username: Lkirkland
Maryville, Tn Usa
Post Number: 12
The one
this is larry kirkland again been back in hospital again heart still not working to good can you send me safe bins nd loader for 2500 pansat not clone my e-mail is lkirkland1948@aol.com thanks if yo can i hope i can remember how to do it again because of all this pills they are giving me
Username: Hotride
Dunnville, Ontario Canada
Hi! I'm not new to sat tv but i think that i have missed something over the last couple of weeks. I used to be able to come here and find keys posted that i could enter manually, but now it seems i need cables and bins to watch tv. Does anyone have working keys that i can input so i dont miss survivor! lol thank you in advance.
Username: Albino_midget
Post Number: 195
you can watch survivor with these
for other channels you may need a new bin
Username: Hotride
Thank you Albino. I had this code but i had an f instead of a 5 at the end. Now i might be a dumb canadian but i have a pantec ultra that i have had for two years with very little time being down. What do i need to get these bins and how do i input them. I had a roolover program at one time but when things got bad the guy i got it from closed up shop and disappeared now i need to start learning all this stuff from scratch. Any idiotproof help would be great. thanks again.
Username: Harjun
Post Number: 24
the new dishnet key is not working in ariza700
Post Number: 196
hashhu dot com has the new bin 280t and loader. you also need the correct cable . you could ask there or start a new thread here for pantec help. i have little knowledge of pantec. good luck
keys posted above work for dn
Username: Hotride
Thanks again Albino. I'll do that! right after i watch survivor. Hope to talk to you again soon.
Username: Harjun
Post Number: 25
PLEASE TELL ME MAKING A CONNECTION BETWEEN PC AND STB BY USING RS232 CABLE.WHAT IS THE MEANING IT ALSO TELL ME MEANING PC
Post Number: 197
you need rs232 cable to get new bin from your computer(pc) to your ariza(stb)
Username: Harjun
Post Number: 26
I WANT TO DOWNLOAD ARIZA 700 BIN GIVE COM SETTING
LIKE SERIAL PORT,BAUD RATE,STB MODEL,BIN FILE,AND FILE TYPE
Username: Dude123
Post Number: 231
larry kirkland
I donnt think i remember you cuz i talk to like 100s of people on this forum so sorry to disappoint you but here is the info i can give you. go to dsstester dot com and you will find the bin and the loader and everything there for pansat 2500
Username: Eliaselias
Hi any idea if there is a fix for megasat 2700xl thanks
Username: Kbee
anyone have keys for rex-i pls help me!pls
Username: Randy_jan
The One: again its the ariza 700, i would like you to send me :
- full instructions and the right cables and ports
- the new bin
- the new loader
my email is : raed_jan@hotmail.com
thanks in advance
Username: Sqman
Midhurst, Ontario Canada
Post Number: 20
ok...i need help. I have a views*t lite, updated the latest pgm (060924as_platinum) but BEV is black exept for preview chanels. Now, i have the new keys, but how do i enter them???? My problem is where in the code window do they go????? Do i just enter them continuously? because there are more keys from the keygen that are allowed for each line in my satellite. By default, the keys are FF FF FF FF....
Username: Enanita
AguadaPuerto Rico
Post Number: 15
Hi there, does anyone have a channel list with all PPv for c*sat 4k, please PM me if you do...enanita@coqui.net thanks
Username: Dude123
Post Number: 232
ray jan
Go to the following link for the new ariza bin file and new loader and you also need a null model RS-232 and don't forget to remove the * from the links below!
http://dsstester*.com/files.php?cat=21-->For Bin
http://dsstester*.com/files.php?cat=12-->For Laoder
Username: Brucester
Post Number: 67
just lost bev ned new keys please
Post Number: 128
need new keys... Any one got them?
Username: Chilien_star
Post Number: 62
the keys does not work
Username: Mc_sunny
Post Number: 409
New Keys for Bev
10/06/06
96=5b14377e7a733c38c068d5a957c213d5
Post Number: 64
is it for 01 or 00???
Username: Mc_sunny
Post Number: 412
Bell Expressvu:
00: 4F 11 A4 DB 3E 22 85 78 6D FC 54 38 A4 05 20 A9
01: 5B 14 37 7E 7A 73 3C 38 C0 68 D5 A9 57 C2 13 D5 (Active)
