Username: Swirvin Post Number: 19 Registered: Feb-05
Saturday, October 07, 2006 - 19:56 GMT i had to load a new bin onto my pansat. never done that before so it was a challenge. but now i am missing quite a few channels, espn, mtv, discovery. anyone have them? the point of all of this for me was to get espn and michigan/michigan state.
Username: Bones714 SO.California
Post Number: 120 Registered: Mar-05
Saturday, October 07, 2006 - 20:39 GMT Yeah, it's your satellite selection. You wanna aim at the 119 bird, most likely your aiming at 110 right now. Like I said aim at the 119 then do your Blind Scan.
Username: Swirvin Post Number: 20 Registered: Feb-05
Saturday, October 07, 2006 - 20:43 GMT well, ive never changed my birds and they worked before with the older bin till it went down. my pansat does not have a "blind scan" option, i have sattellite scan tp scan network scan advanced scan
Post Number: 123 Registered: Mar-05
Saturday, October 07, 2006 - 20:49 GMT What model Pansat? What Satellite/Echo are you using?
Username: Swirvin Post Number: 21 Registered: Feb-05
Saturday, October 07, 2006 - 20:53 GMT pansat 2300 echo 7 and echo 8. any idea why i am missing espn? on my previous bin that i had paid someone to do it, it was channel 140. now channel 140 amongst others does not even come up.
Post Number: 124 Registered: Mar-05
Saturday, October 07, 2006 - 20:58 GMT I'm not sure about the 2300, try a advanced scan. You got nothing to lose, but you may get double channels.
Username: Cramped Post Number: 38 Registered: May-06
Saturday, October 07, 2006 - 21:18 GMT Try deleting all your channels and shut the receiver down (turn the switch off at the back) for a few minutes. Turn it back on, do a satellite scan on whatever birds you are aimed at and you should get all channels.
Username: Swirvin Post Number: 22 Registered: Feb-05
Saturday, October 07, 2006 - 21:33 GMT king, i'll try that later. somehow in scanning here and there it popped up but everything is a mess. i got it with 7 minutes left in the first quarter so thanks for your help. i'll try that solution you offered later.
Username: Charjam Post Number: 28 Registered: Sep-06
Saturday, October 07, 2006 - 23:13 GMT I have a pansat 2500 and i have the same problem it comes and goes . It goes from o sig to 90 . Hope someone can help us Thanks
Username: Crazy_greek Post Number: 104 Registered: Jul-06
Sunday, October 08, 2006 - 12:06 GMT Hey Guys Use Advanced Scan is the same as Blind Scan. See if your mast is level. (both sides) Check Dish Alignment.
