Hey newbie here so bare with me. I turned the autoroll off and put the new keys in last night, everything was great. I woke up this morning and all channels gone, only have radio ? What can I do to get channels back?
You probably hit the Sat/Music button, Look on your remote for a Sat/Music button and press it. If that doesn't work, start hitting buttons on that remote.
Allright I did a sat. scan and I got them all back. But I was told by the guy I got this from when I lose channels don't scan. He says go to the channel list go to channel 100 and click and it's supposed to bring them back. But I've yet to see that work, and I didn't have a channel 100. I dunno but Jr's got his toons so screw it. lol. Thanks alot for the quick reponses!! You guys rock!!
help i have a pansat 2700a with the bin x-87bl API:2.74c_EUbX boot ver:6.2 27 sep 2006 on it, or atleast thats what my system info says. i see these post about new keys that you can punch in i tried but i think iam doing something wrong... iam also currently pointed to bev with my dish and using nimiq 1.2 ku for the sat if this helps you for figuring what i have and where iam at
Did you got the keys for Di*h or for BEV?, there are 2 different sets of keys, you need the keys for BEV, after enter each one of the key don't forget to press the OK button on your remote before going to the next key.......you also must turn off all the autoroll option and leave just the keycode option on.
thanx this all is good and it all works again.... i also found out if you get no signal after a while just shut off and turn on the switch in the back of the receiver...thanx again long live pansat
