TP Update
Username: Kjniceguy
Lethbridge, Alberta Canada
Post Number: 94
I was Just wondering why my pansat 2500a goes through so many TP UPDATES...I loose Channels every time, and the tp frenquency is completely gone...no signal. Any suggestions or comments ?
Username: Erick
how do i putt the key code to my dish network!! HELP!!
Username: Lroy
Post Number: 96
To correct this problem first go to menu,user setup, and select off on TP auto update then rescan or reload your channel list. Always ensure that TP auto update is off...
