Diamond Audio Speakers
Username: Nyyfan13
VA USA
Post Number: 253
im gonna order my SSD either tonite or tomorrow. i need to get some new speakers too. im looking at getting Diamond Audio speakers, comps for front, coax for back.
Are Diamond Audio speakers legit?
Front - Ran of a Phoenix Gold R4.0:2 amp
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15029
Back - Ran off headunit
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17167
does this set-up sound alrite or is there a better set-up i could get for about $300-$350?
(5 1/4 up front, 6 1/2 in the back)
Username: Basshead86
Try Google
Post Number: 6782
get some Crystal CCSC's.....they are veddy nice, and not all that expensive for what you get.
i have never had first had experience with Diamond, but their products look mediocre at best.:-)
Try Google
Post Number: 6783
on that website...i would either go with the MB Quarts or the JL's:-)
Username: Nyyfan13
VA USA
Post Number: 254
how about these for the front
http://www.infinitecaraudio.com/cgi-bin/icastore.cgi?user_action=detail&catalogn o=CSC50T
powered by the same amp, the speakers are 65rms, amp does 75 rms.
and these for the rear
http://cgi.ebay.com/MB-QUART-DKF-116-6-1-2-2-way-6-5-Speakers-DKF116-NEW_W0QQite mZ300034229597QQihZ020QQcategoryZ18799QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
powered off headunit
does this set-up sound better?
Try Google
Post Number: 6784
do you like metal or silk tweets?
that is something you need to take into consideration:-)
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 9391
Yes much better
Username: Nyyfan13
VA USA
Post Number: 255
muddy,
i myself i have no idea because i have never owned any car audio equipment nor have any of my friends. everything i have learned, which still isnt much, ive learned from this website.
which ones sound better, silk or metal? pretty much which one do u like better cause ur very knowledgable of this stuff and im gonna take which ever one u say and use that one.
Username: Nyyfan13
VA USA
Post Number: 256
didnt bump...
Try Google
Post Number: 6785
i personally prefer the sound of Silk Tweeters...they are more laid back, not as aggresive.
if oyu like extremely loud tweeters....then get metal, if oyu want a more natural sounding...get silk(my opinion, as you can tell, i have had bad experiences with metal tweets.lol)
Username: Nyyfan13
VA USA
Post Number: 257
haha, alrite well i think im gonna go with the second setup with the crystal and mb quart speakers. im gonna take a chance and see how the metal tweeters sound and hopefully i like it. thanks for the help.
Username: Mikechec9
Post Number: 2460
I like Diamonds. Not smooth and full, but "neat" and detailed. The D6 and 9s are good for the $.
I've had good experiences with both, but I'm more of a smooth and full type.
Username: Mikechec9
Post Number: 2461
These were fed by TRU amps fwiw.
Username: Nyyfan13
VA USA
Post Number: 258
i was thinking, do i really need rear speakers? my sub would be right behind the rear seat. would the sub make up for the loss of the rear speakers? its a real small hatchback car (scion tc).
or shuold i get some rear speakers?
