New stb for megasatPro coo*lsat clone tested
Username: Lichmc
Post Number: 13
http://www.tranlich.com/dss/01oct2006/MEGASATPRO/
Username: Kato1
Post Number: 136
HEY CAN ANYONE TELL ME IF 110 ECHO 8.6 NAME HAS BEEN CHANGE?? HOW ABOUT 119 ECHO 7?? THX...KATO1
Username: Lichmc
Post Number: 17
NEW KEYS 06 OCT 2006 04:50: pm
*** FOR PANSAT, MEGASATYT, FORTEC
1) Go to Parental Control, then go to Autoroll option at the bottom
2) Change Dishnest Autoroll to OFF,
3) Keep KeyCode on the first line ON
4) Exist to previous menu, then go to Nagravision 2
5) Change the new keys:
00==> 0C FA 39 73 91 5F F5 54 E9 56 1C 42 8B 7A CA B2
01==> 66 B9 F6 53 70 ED 2A 5B 31 D5 59 D2 9F 1C 52 63
remember you must have number 70 in the 01
66 B9 F6 53 70
You can download program "KeyRipper V2.0.zip" to get the new keys in software folders
*** FOR MEGASATPRO, COOsLSAT, COOLTECT
1) Press MENU, goto Autoroll Options in Installation
2) Change Echostar Autoroll to "DEACTIVE"
3) EXIST, then press 8282 for change keys menu
4) Make sure CAS is Nagravision, Ident is Dish network (0001)
10==> 0C FA 39 73 91 5F F5 54
11==> E9 56 1C 42 8B 7A CA B2
20==> 66 B9 F6 53 70 ED 2A 5B
21==> 31 D5 59 D2 9F 1C 52 63
