MTX 404 Noise (GlassWolf)
Username: Elexpert
Post Number: 27
Just installed this MTX 404 amp in my car. After hooking it up, with the gains turned all of the way up I hear a loud noise. The RCA cables aren't close at all to the power wire. And the noise is present when the cars off also. THX for the help in advance.
Username: Its_bacon12
Post Number: 549
well turn your gains down a bit im sure the amp is clipping when you turned them all up allt he way...
turn them to about 1/2 then see how it sounds
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2809
the gains shouldn't ever be more than about half way up.
they are to balance line voltages, not meant as a volume knob. they have no effect on the amount of power the amp generates.
the gains are the cause of the noise
Username: Elexpert
Post Number: 28
and I am officially a jackass. Thx lol
Username: Glasswolf
Post Number: 2824
common mistake.
