Bronze Member Username: BigbenPost Number: 15 Registered: Oct-06 | is it smart to hook up 4 subs to a really big mono channel amp?? could i just hook up 2 subs to each terminal or would that not push as much power. please help becuase i am confused |
Gold Member Username: RovinTrinidad & T... Post Number: 9271 Registered: Jul-05 | once the ohms & wattage match up yes u can do it say ur amp does 1000wrms @ 1ohm then u can use (4) 2ohms dvc subs which r 2500wrms each & ur good 2 go use this wiring guide http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =1 ...... |
Gold Member Username: RovinTrinidad & T... Post Number: 9272 Registered: Jul-05 | """say ur amp does 1000wrms @ 1ohm then u can use (4) 2ohms dvc subs which r 2500wrms each & ur good 2 go""" i meant say ur amp does 1000wrms @ 1ohm then u can use (4) 2ohms dvc subs which r 250wrms each & connected together = a 1ohm load & ur good 2 go ....... |
Gold Member Username: TjmutlowPost Number: 2901 Registered: Sep-05 | or 4 single 4ohm sub...... |
Bronze Member Username: BigbenPost Number: 19 Registered: Oct-06 | ok what if i get 2 L7's that are 2 ohm and hook them up to a kicker kx2500.1. would this amp blow the subs because the rms wattage is more than the sub rms??? should i get a smaller amp that is around the same wattage but not over? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2748 Registered: Dec-05 | what l7s?? 15?? if they're 15 then you're good to go. If they're 12 then you should turn the GAIN down |
Bronze Member Username: BigbenPost Number: 21 Registered: Oct-06 | yes the 15inch. now what would be the best option for makin sure that the amp doesnt kill my battety? |
Bronze Member Username: Aj1218Post Number: 24 Registered: Jun-06 | hook up a capacitor directly from the battery to the amp |
Silver Member Username: Tdawg30Ohio USA Post Number: 319 Registered: Jun-06 | no dont use a cap. unless you have a high output alternator and the Big 3. |
Bronze Member Username: Aj1218Post Number: 27 Registered: Jun-06 | yea that's true. A high capacitance capacitor can end up draining the battery more |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2755 Registered: Dec-05 | just create one thread RYan and please avoid l7s, get some good subs or at least one good sub |
Silver Member Username: Freezeman_7Lindsay, Oklahoma Post Number: 350 Registered: May-06 | ^^^haha agreed about the 7's |
Bronze Member Username: BigbenPost Number: 27 Registered: Oct-06 | whats so bad about the L7s. i thought they were one of the best subs around?? |
Silver Member Username: Killer44Ontario Canada Post Number: 686 Registered: Dec-04 | yeah right...were did u hear that...dont get me wrong they will get loud as he!! in the right box and with lots of power, but theyre sq is terrible, much better subs out there trust me... |
Bronze Member Username: BigbenPost Number: 30 Registered: Oct-06 | i dunno where i heard that but i jsut thought they were louder. what other subs should i get?? any suggestions?? |
Bronze Member Username: TinytruckDuluth, Ga US of A Post Number: 16 Registered: Oct-06 | hey is there sound quality that bad or is it just when they are pushed to the max because i just bought two of the 15 inch dual 4 ohm and they sound amazing but i dont push them all the way just what the guy two blocks down can withstand!!! |
