Username: Camarobump Post Number: 51 Registered: Sep-06
Friday, October 06, 2006 - 16:25 GMT I just bought 2 new 12" subs and the specs are 1100w rms, 30Hz-500Hz, Dual 4 ohms, 2 Ohms or 8 Ohms operation. What would be a good amp to go along with these subs?
Username: Drsmith Montana
Post Number: 1173 Registered: Nov-04
Friday, October 06, 2006 - 16:37 GMT quote: Dual 4 ohms, 2 Ohms or 8 Ohms operation
uhhh...... what what impedence are the subs, it cant be all 3, also what model are they
Username: Bestmankind Los Angeles,
CA
Post Number: 6115 Registered: Oct-05
Friday, October 06, 2006 - 16:40 GMT its a dual 4 ohm and it can be wired to 2 or 8 ohms. a kicker zx1000 would be a decent choice.
Username: Tjmutlow Post Number: 2908 Registered: Sep-05
Friday, October 06, 2006 - 17:06 GMT no the zx is only rated at 2ohms, you need a 1 ohmstable or a 2 channel amp bridged. ****what brand sub are you running?
Username: Hockeyknight Post Number: 373 Registered: Apr-06
Friday, October 06, 2006 - 17:24 GMT are they 1100 rms each or for both subs?? and whats ur amp budget??
CA
Post Number: 6117 Registered: Oct-05
Friday, October 06, 2006 - 18:05 GMT oh my bad. a kicker kx1200.1 then.
Username: Rovin Trinidad & T...
Post Number: 9277 Registered: Jul-05
Friday, October 06, 2006 - 18:13 GMT just post the exact sub model no so ppl here trying 2 help u wont be guessing .......
Username: Camarobump Post Number: 52 Registered: Sep-06
Friday, October 06, 2006 - 21:59 GMT My bad, they are Digital Audio 9012 Excursion series. Yes, each of them is 1100w rms. My budget is around $200. I really appreciate any help.
Username: Juliob Santo DomingoDominican Re...
Post Number: 2766 Registered: Dec-05
Friday, October 06, 2006 - 22:02 GMT you need a 2200w rms amp at 1 ohm. I don't think you can find an amp for 200$ The best for the budget would be PA a3000db
Username: James1115 Ct
Post Number: 6681 Registered: Dec-04
Saturday, October 07, 2006 - 02:48 GMT save up and broaden your budget. You get what you pay for.
Username: Camarobump Post Number: 53 Registered: Sep-06
Saturday, October 07, 2006 - 05:07 GMT Do ya'll know of any amps that put out 2200w rms at 1 ohm?
Post Number: 6699 Registered: Dec-04
Saturday, October 07, 2006 - 05:14 GMT just get a orion 2500d or a kicker 2500.1 the extra 300 watts is so minimal at that amount of power it wouldnt even be noticable.
