Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2709 Registered: Dec-05 | http://cgi.ebay.com/BRAND-NEW-2006-CLARION-DPX11500-MONO-POWER-AMPLIFIER_W0QQite mZ250035481619QQihZ015QQcategoryZ18797QQrdZ1QQcmdZViewItem Someone knows if that amp is good, it says CEA compliant and i've seen some clarion amps with good build quality, if that amp is really CEA 2006 then is a must have... the budget amp for the zx 1500.1 from kicker. Anyone??? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2722 Registered: Dec-05 | nobody owns/heard about clarion amps?? |
Silver Member Username: MakmillionMN United States Post Number: 885 Registered: Apr-06 | I use to have an apa series clarion 4 channel.. I think it was an APA4212 or something like that, it sounded amazing.. but an installer blew the rca input at audio king (now it's ultimate electronics) |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2734 Registered: Dec-05 | ok, some1 else, ^^^^ great deal for 260$ if it's good |
Gold Member Username: James1115Ct Post Number: 6668 Registered: Dec-04 | I looked into it a little more and the more I look into it the nicer it look's |
Gold Member Username: RovinTrinidad & T... Post Number: 9270 Registered: Jul-05 | i admit it does look good on paper (not really digging its looks tho) idk much about clarion stuff except they make decent HUs & speakers 4 the $ but i dont think they r known 4 their amps however . This CEA 2006 compliant - doesnt it mean it does as advertise but @ 14.4V ??? which means it will only put out that if u use a HO alt since i think normal stock alt only goes up 2 13.8v so honestly u wont be seeing that full wattage in all 2006 amps right ? ......... |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2743 Registered: Dec-05 | well rovin, for the price, if you get 1200-1300w rms, i don't care hehe and the amp might be underrated cuz that BIG 200A fuse hehe is making me kinda crazy... I've seen some interiors on clarion amps and they do look nice |
