Silver Member Username: Xstokes88San Antonio, Texas United states Post Number: 108 Registered: Nov-05 | anybody know any websites to make a box with..ive been lookin on here but i cant find em..thnx for the help.. |
Gold Member Username: DrsmithMontana USA Post Number: 1115 Registered: Nov-04 | www.subwoofertools.com |
Gold Member Username: Logan__tilleHamilton, Indiana United states Post Number: 1464 Registered: Feb-06 | http://www.subwoofertools.com/forum/ported-box.asp |
Silver Member Username: Xstokes88San Antonio, Texas United states Post Number: 109 Registered: Nov-05 | o ok..thanx..but can anybody help me out wit this..my deminsions are 12*24*32.. |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3805 Registered: Oct-05 | then just put them in there.. then ur box volume and ur desired tuning. you also need to know the sub displc. each sub is, and the exmax in mm (these can be found just in the manual or on their website prolly) |
Silver Member Username: Adam_sWisconsin USA Post Number: 294 Registered: Aug-04 | What sub(s) are you making the box for.....and what are you trying to acheive from them sq or spl |
Silver Member Username: Xstokes88San Antonio, Texas United states Post Number: 110 Registered: Nov-05 | they are L7s 12s..im goin for more spl..i kno there are better subs but i got a good deal on em..already have an amp..just looking to find out what kind of box i need to make because of space limitations.. |
Silver Member Username: Adam_sWisconsin USA Post Number: 295 Registered: Aug-04 | well if your space is limited you might want to go sealed but it wont be as loud as ported |
