Is it possible to get Bev 82/91 on same dish?
Username: Tariqic
Post Number: 65
Is it possible to get Bev 82/91 on the same dish? I have a Dish500Pro and one wire coming in from one of the LNBs. If yes, how? Thanx in advance.
Username: Dancuban
Post Number: 23
i don't know mush but yes you can catch 91 an 82 on the same dish, as for using a dish 500 i'm not sure. maybe lk could help you on that front. to get the 2 birds you want, you may have to get elliptical dish (photo attach) Upload along with 2 dishnet lnb.
Username: Letmeon
Post Number: 60
Seems possible by looking at the numbers.
110 and 119 diff is 9 degrees
91 and 82 diff is 9 degrees
Both are the SAME difference
so aim 110 LNB at 91, skew should the same, but
azmuth is higher.
Username: Fidarahman
Post Number: 49
Yes it is possible with TWO LNBs as shown above by dancuban
