Programing to Centeral Time... Bluez Help!!!
neonb
I can program my card to Eastern timing but not central, I even use the central infromation but I am only program Eastern time. I would like to have Centeral time on my HU Card.
Username: Bluez
Post Number: 47
if you want central time then you must put in central locals and the right zip code for that area
neonb
I did but it gives me eastern timeing. What do you think it is.
Username: Bluez
Post Number: 48
if your 3m or act already have it built in then you need to change area info in extreme after loading 3m or act
neonb
I do not know if it me or what but I change the information to Centeral time and still get eastern time. I used a bin with all channels and change the location information and I get all channels for eastern and western times.
HELP!!!
Username: Bluez
Post Number: 49
in extreme hu you must put in your local market then the proper zip then the right time zone for your area, on the tool bar is a little map click it, or you must find a hex for your zone and put it on top of 3m
neonb
Thanks,
I will try that....
Username: Topdog
I finally got my USB to work (went there could not get serial port to work)but still not detecting my device. I am not sure if my Mik 3 is even working. Any thoughts on checking it. I don't now anyone who I could check it out with, just bought it last week. Also is it worth changing OS to 98.
neonb
Bluez, do you know of any sites that would have hex for my time zone?
Username: Bluez
Post Number: 51
well
application/x-zip-compressedlocals hexes
Step # 3 Local hex's.zip (15.3 k)
Username: Dtvmaster
Usa
Post Number: 30
Dtv loaders Paypal and moneyorders accepted email dtvmaster@aol.com
I sell these at 90.00 shipped with Newbee cd included includes all software too get started .
If u do not need the cd then its 75.00
Free shipping These come with powersupply and cables . compatible with all dtv cards
dishnet loaders available also email dtvmaster@aol.com thanks again
Thanks Bluez, I needed that. U R an asset to this message board.
I got ATMEL error "V6.1 not supported !", my loader has not dip siwtches. What should I do ?
Username: Yogicell
In Canada, In Canada Canada
Help...........please help me.
Im new at this Dish network stuff, I am use to DTV, but now that Dave has killed my Tv, I must change. I need to start from the beginning, What do I need, and where do I go, from here. I have a loader, but not sure if it will work with Dish/Bev
Please help me
Username: Notvforme
Post Number: 9
hey if you go out side and look at your sat see were it is pointing all you have to do is buy a new thing called a brain! it allowes you to look at the stream right while it comes into the lnb! peace
